Thread: another leak question
    Apr 2010
    Central NJ
    227
    I have three valves on my suction side, one for the main drain and one for each of the skimmers. I accidentally closed all three valves with the pump running for about a couple of seconds and then opened the valves back. Right after this, the pump is moving little water, like if it had a suction side leak. It's so bad that the pump basket isn't even close to filling up. Has anyone seen this happen before? Did I damage my valves?
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    30,400
    Re: another leak question
    The valves are likely just fine. Take a close look at the O-ring around your pump basket lid. With the valves closed, there is quite a bit of force trying to suck in water and it may have dislodged that O-ring.
    Apr 2010
    Central NJ
    227
    i did take a look at the o-ring, reseated it and lubed it. I guess next step would be the screws in the basket. I will take a look at this tomorrow.
    Apr 2010
    Central NJ
    227
    I found "the leak". I was vacuuming leaves and I forgot to put the basket in the skimmer so they ended up in the drain basket. I proceeded to touch the impeller and noticed that it was full of leaves. Once removed, the pump was back to normal.
    philc's Avatar
    Jul 2015
    Grand Island Nebraska
    190
    congrats
    Intex 22' X 52" Ultra Frame AGP ( 12K gallons) , Intex 633T 2500 GPH (41 GPM) running Doughboy Silica II sand filter (16"dia. 1.4 ' S.A.) ( And doing it quite well, I might add!) Hayward through the wall skimmer, TF100 with Speed Stir. Hard plumbed, Intex fountain ...........
