Thread: Vinyl Liner Stuck to Horizontal Metal Beams
    Jul 2014
    ny/ny
    4
    I have an Intex Ultra Frame Pool 18x9x52 and we are taking it down for the winter. We drained the water and dried the pool up. Now we are having trouble with removing the horizontal metal beams from the liner. We were able to stick a broom pole on the short side (9 feet) from both ends and after a while were able to separate the beams from the liner and remove them. Now we have a problem with the long side as the broom pole is too short to reach the middle from either side.
    If anyone knows of a way to do this please share it.
    Thanks.
    Reg H., Queens, New York City
    Intex Above Ground Ultra Frame Rectangular Pool 18' x 9' x 52', 4545 Gallon, Intex CG-28669 ECO8110 Salt Water Generator, Krystal Clear Sand Filter 1,200 gph SF9010T, City Water
    Taylor K-2006 Test Kit from TFTestkits.net
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Vinyl Liner Stuck to Horizontal Metal Beams
    A longer pole?
    Sorry, not sure what else to suggest, but maybe a bump will get you some better ideas.
    Essential Links:
    philc's Avatar
    Jul 2015
    Grand Island Nebraska
    190
    Sometimes a gentle twist of the beam is sufficient for the vinyl to release its grasp.
    Intex 22' X 52" Ultra Frame AGP ( 12K gallons) , Intex 633T 2500 GPH (41 GPM) running Doughboy Silica II sand filter (16"dia. 1.4 ' S.A.) ( And doing it quite well, I might add!) Hayward through the wall skimmer, TF100 with Speed Stir. Hard plumbed, Intex fountain ...........
    Sep 2016
    El Paso, TX
    1
    I having the same issue, whit a intex pool I try soapy water, hot water but nothing. Any suggestions????
    Sep 2016
    oklahoma city
    1
    Spray WD40 down the length of the pool at the support holes between the metal and the vinyl! I was having the same issue, this WORKS! YAY!
    Jul 2015
    Charter Oak, California
    275
    I just took mine down. I used my fingers at every leg hole opening while rotating the top rail a bit and just worked it loose from the outside where I couldn't reach. Didn't take too long. I did get frustrated, but calming down and staying at it worked for me..
    Bob (AKA Schnozz)
    12 x 24 x 52 Intex Ultra Frame AGP, 8600 Gal; Pentair 2HP/2SP 150sqft Cartridge Filter; Hayward Through Wall Skimmer; Intex Automatic Cleaner (Fantastic); K-2006 Test Kit; Start-up 07/30/2015. First Time Pool Owner in SoCal.
