Thread: Correct FC level before closing
    Jul 2015
    Cape May Court House, NJ
    121
    The pool company is coming day after tomorrow to do my closing, and I'm getting the water chemistry right before they get here. I've read the stickies in this forum, but I'm just not quite clear on what to do with the FC level. Do I bring it up to shock level or to 50% of shock level? And then I leave it there and let it sit for the winter? (It will be covered, of course.) I don't have any plans to add Polyquat or other algaecide.
    My FC right now is 3, CC is 0, pH is 7.5, and CYA is 40. I just added the last of the chlorine in a 2.5 gallon carboy, and I think that's enough to raise the FC to about 10. I'll check that in the morning. Shock level is 16, so I'm going to be fairly close, but I also want this to last until March or April. I can pick up some gallons of bleach at Walmart tonight if necessary.
    22K 16'x40' inground fiberglass pool, Hayward Pro Series High Rate Sand filter, Hayward dual speed 2 hp Super II Pump, Hayward AquaRite SWG, Raypak 400K btu propane heater, Dolphin Supreme M400 cleaning robot, CoverPool auto cover. Also stand-alone Sundance Hawthorne 430 gallon hot tub.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Correct FC level before closing
    Hi,
    the winterizing instructions in Pool School have worked very well.
    Pool School - Closing (Winterizing) Your Above Ground Pool
    Quote Originally Posted by Maestro View Post
    Divin Dave,
    Jul 2015
    121
    Thanks for the quick reply, Dave. I don't know how I missed that article! I'll bring it up to shock level as soon as possible.
    The pool is brand new this summer and I haven't had a speck of algae yet thanks to this forum, so I want to do everything I can to keep it that way and open it up clean and clear in the spring. Wish me luck!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi Maestro,
    Its great to hear another positive comment on how well TFP works!
    Good Luck to ya!
    Lets hope you have a troubelfree opening come springtime!
    Divin Dave,
