Thread: Fill Water Test
    Oct 2015
    Burleson, Texas
    178
    Fill Water Test
    What tests should I run before the pool is filled? I just got my TF-100.
    21,000 gallons, Salt, IG Gunite, Plaster Finish, Free From, Pentair FNS DE cartridge filter, Pentair Intelliflo-VS pump, Intellichlor IC-40, 2 port fountains, bubbler in tanning deck, Dolphin M400, TF-100, K-1766, Speed Stir
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,476
    Re: Fill Water Test
    Everything BUT CYA. Post up the results!
    Kim
    Oct 2015
    Burleson, Texas
    178
    Re: Fill Water Test
    Here are the results...
    FC = 0
    TC - 0
    CH= 175
    TA = 100
    CL = 0
    pH = 7.5
    Jul 2012
    Tallahassee, FL
    30,476
    Re: Fill Water Test
    Nice water you have there!
    I am going to shoot you a couple of links so YOU know what to have on hand when your pool is filled. ASK any and all questions to make sure you are doing things the best way.
    Pool School - Start-up New Plaster
    Print this one out and keep it by your test kit:
    To help with your shopping list......I would also get a white plate or such to hold the test tube in front of to help with the color matching.
    To help with the math. This link does all of the work for you! SO neat!
    http://www.troublefreepool.com/calc.html
    Print this one out also.
    I hope I have not overwhelmed you. Just take it a step at a time and ask questions as needed!
    Kim
    Oct 2015
    Burleson, Texas
    178
    Re: Fill Water Test
    Thank you! Hopefully we can get this pool finished in between periods of rain over the next couple of weeks.
