Thread: Down east spa 2 pump system jets 2 not working
    Nov 2015
    EIGHTY FOUR Pennsylvania
    1
    My jets 1 work which is the 2 speed circulating pump bur when I press jets 2 the relay in the circuit board just clicks. The last motor burned up and I replaced with a new one. I am only getting power to the black wire and not the white. The fuses are all good and I put power to the motor so I know it works and the jets 2 button lights up and relay clicks when pressed.
    Aug 2015
    Maine
    45
    Re: Down east spa 2 pump system jets 2 not working
    Did you check the power back at the disconnect to make sure you have two hots?
    Jun 2015
    Wildomar, California
    423
    Is the pump 110 or 220? Since black is line power and white is normally neutral, what is the voltage to the motor? That answer would help us. Also can you check voltage at the power source to the motor, ie contactor, relay, etc?
    Aug 2015
    Maine
    45
    Pretty sure all down east spas require a four wire 220 circuit....
