Results 1 to 10 of 10
Thread: Another pool first- acid whiff!
    steve57765's Avatar
    Aug 2015
    Lexington NC
    47
    Well, yet another first for my pool ownership. Just added Muratic acid to pool and when pouring into measuring cup, 1 quart version, then into water slowly, long enough for fumes to make it up to my nose!
    I was holding my breath, not long enough obviously because I was doing this all "slowly" as not to splash it. But slow enough to where I had to take a breath, and Bam! Nose burn! I walked up wind, looked back, and I could see the cloud of fumes drifting away.
    So next time I'll pour into measuring cup, up wind away from pool, Take a breath, take to pool and pour slowly, up wind again.
    Any advise?
    Steve- 19K IG PebbleTec (sandy beach color pebble) final plaster/pebble August 2015
    Jandy pro cartridge filter
    Jandy pro series Plus HP PHPF pump w/waterfall
    Polaris 360 pressure cleaner- TF-100 w/SpeedStir
    50ppm Borates
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Another pool first- acid whiff!
    Don't use a measuring cup. The less exposure to air the better. I just estimate the quantity I'll need, carry the jug to the edge of the pool near a return, uncap it, hold it out with the bottom touching or just under the water and pour a pencil sized stream into the pool. Also pick the side of the pool that puts you upwind. A couple ounces difference in thousands of gallons of pool water won't make much difference.
    chiefwej
    30,432
    I can't improve on what chiefwej says.
    Upwind is the key.
    steve57765's Avatar
    Aug 2015
    Lexington NC
    47
    I thought I was up wind, it was very clam, no breeze. Fumes just drifted up, which is why I could see the cloud of fumes, (I guess anyway). Pouring into container is probably what caused all the fumes. As suggested, no more measuring for me!
    50ppm Borates
    Jul 2014
    Sacramento, CA
    241
    I took an empty jug and a stick, and used a measuring cup to put a quart of water at a time into the jug, marking the level each time on a 1x2 stick I had. Now before I open a new jug, I take the stick and a sharpie that lives next to it and mark the quart lines onto the new jug. Helps me with estimating when I pour it in (a quart of 31% is about the amount I usually want to put in).
    I used to be a cup measurer until doing it at night under a headlamp once where I could really see the fumes rising. That, and the thread here from the guy who had some eye injury from pouring (he was wearing a respirator, which may have made things worse because now you don't have your nose to give you the early warning to get away) convinced me that direct pouring was the best method. I'm especially not a fan of doing extra steps like pouring into a bucket of water, walking around distributing it, etc. Just sit steadily in one place, pour in front of a return, and let the pump do the distribution.
    21000gal IG plaster, Sacramento CA area (late 1950s/early 60s)
    Filter: Cartridge, Pentair CCP420 (2014)
    Main pump: Pentair IntelliFlo VS (2015)
    Boost pump: 3/4hp (2011), Polaris 280 cleaner (unknown age)
    steve57765's Avatar
    Aug 2015
    Lexington NC
    47
    Excellent tip! I'll do that with my next empty jug
    thanks. That would be a great "tip" to add to the tip thread,
    A couple of tips I thought everybody knew. Anybody got some
    It's your tip but I would be happy to add it for you
    50ppm Borates
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    492
    i take the bottle and pour a guesstimate amount in front of return reasonably quickly
    with my head turned the other way
    usually a 3 second pour out of bottle drops my ph 0.4-0,5
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    Jul 2015
    Western NC
    115
    Quote Originally Posted by aussieta View Post
    I do that, too - and I use the 20% "green" MA because it produces less fumes and is more forgiving to inaccurate guesstimates.
    23,000 gallons IG gunite, pebble (I think)
    Hayward SP2610X15 1.5 HP Pump, Hayward sand filter
    Mineral Springs SWCG (it's actually Hayward/Goldline), Hayward Goldline T-CELL-15
    Polaris pool cleaner (with booster pump)
    TF-100, SpeedStir, K-1766 Taylor Salt Test, Lamotte Borate test strips
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    I hold breath and position it up wind but fill a 1 gallon bucket halfway first and pour it in that then slowly
    move it around before slowly pouring it all in to a return jet area.
    Dolphin E10 Cleaning Robot.
    wjr75's Avatar
    Jun 2013
    IL
    836
    I hold my breath but seems to get me at least once a year
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
