Thread: Local acid wash - how to?
    Jul 2010
    Philadelphia
    134
    So, all season I was never able to budge a ring of scale from my pool left over from the previous winter (Scaling - does it help to add additional chemicals beyond controlling chemistry?).
    I have drained the pool below the ring for the winter closing. I thought of taking a sponge and wiping Muriatic acid over the ring to remove it. Is this something that I would need to leave on, just swipe and rinse .... - anyone know?
    Thanks!
    19000 gal in ground, pebble tec. Sta-rite system 3 DE filter, Aquarite SWG, raypak 406A heater
    Sep 2013
    Charleston, SC
    537
    Re: Local acid wash - how to?
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    Jul 2010
    Philadelphia
    134
    Quote Originally Posted by otter86753 View Post
    Thanks for the bump - things maybe get quiet in the off season
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    chiefwej
    JoyfulNoise's Avatar
    May 2015
    13,213
    Sounds to me like you need a tile cleaning service. I had bad scale around my pool tile (and spa face) after a winter of not properly managing my pool water. I found a local company that did kierserite blasting (a modified form of soda blasting that uses magnesium sulfate). The service cost ~ $3/linear foot of tile and I only had to drain the water below the tile line (~4"). The guys was done in about an hour and my pool tile looked brand new!
    You might try looking in your local area for someone that performs pool tile cleaning. Chemical removal (acid washing) with a sponge is going to take forever and it will probably be patchy at best. Sometimes old scale can become very resistant to acid as the calcium in the scale can get replaced by magnesium and other materials (like silica sand, etc) and become very hard to remove. So the sponge method might work on some lighter patches of scale, but the thicker ones will need some form of mechanical removal. Pumice stones and scrappers are not the best idea as they can scratch the glaze on tiling. Soda blasting is a better alternative because the hardness of the grit is about the same as the calcium scale but much softer than the tile glaze. So the grit blasting can be optimized to remove scale without doing any damage to your tiles.
    Good luck,
    Matt
    Matt
