Thread: Water Swap
    Sep 2015
    Orlando, FL
    22
    Water Swap
    I'm in the process of replacing some water to lower CYA from 80. I'm trying the pump on top, hose on the bottom method. After about 30 minutes the FC coming out of the pump is unchanged, so it is working so far.
    8200g IG, Diamond Brite Plaster, Hayward Cartridge Filter, Pentair Pump, TF-100, Rainbow 320 Inline Tab Chlorinator [not used]
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: Water Swap
    Sounds like a good plan!
    Love TFP? Become a
    TFP Supporter!
    Sep 2015
    Orlando, FL
    22
    Re: Water Swap
    Well, that was completely unsuccessful. My hose only outputs 5 g/m, which means after a little over 4 hours I only exchanged 1300 gallons of water. Because the rate was so slow, and the relative temperatures pretty close, I think I was getting much more mixing than I anticipated. Results:
    Before:
    FC/CC: 8.0/0
    PH: 7.8
    TA: 80
    CH: 400
    CYA: 70
    After:
    FC/CC: 6.5/0
    PH: 7.8
    TA: 90
    CH: 400
    CYA: 70
    Had I actually exchanged 1300 gallons of water, I should have ended up with a CH of 350 (given my tap CH) and a CYA of 60. Even then, I'd be a long way from my target CYA of 40, which would let me do my daily testing with the OTO vs. the FAS-DPD. Oddly enough, the FC drop was withing 0.5 of what I expected (our tap water has an FC of 1), but maybe some of that was due to the pump, weight, hose, etc.
