Thread: Pump primes...kinda...video link
    Oct 2015
    Pentas/TX
    28
    So the pump i got to vacuum pool had a hard time priming, i had flex hoses attached and the leaks from connections didnt make me happy, but i can fix that. Im used to the pentair 2HP Pump on thd pool being water tight, is this pump an exception?
    Hayward sp1580 power flo lx 1HP with cord - YouTube
    40x20 Rectangular (3'to6' depth),Cantilevered Deck, Whisperflo 2HP FullRated, DE 60 SQft Filter, 2 Intellibrite 12V 5G Color Lights, Intellibrite Controller
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Pump primes...kinda...video link
    My guess is the vacuum hose just can't supply enough water to the pump to allow it to fully prime.
    30,403
    Replace your suction side plumbing with a 2" solid pvc pipe (temporarily) and stick the pipe in the pool. If your pump fully primes (and I think it will) then you have a suction leak somewhere in that flex hose.....either a hole in the hose or the fittings that connect it.
    Oct 2015
    Pentas/TX
    28
    Thanks a lot for the replies guys!
