Thread: concentrated liquid bleach vs concentrated germicidal bleach
    Oct 2015
    Orinda, California
    56
    To Forum: is there any difference between liquid concentrated bleach and concentrated germicidal bleach? The liquid bleach is a tiny bit cheaper. I assume both have strengths of 8.25%. Web site does not specify strength. They say 121 oz of concentrated is equivalent to 182 oz of un concentrated. I am assuming I want to buy the regular liquid bleach, but I wanted to check with the board. Whatever I purchase I will check product manufacture date. thanks, TJ
    28,000 gallon IG pool, plaster, built approx. 1970.
    1 1/2 " plumbing. Pentair, Intelliflo 3 hp variable speed.
    Crystal Water cartridge filter system, model #425
    Dolphin Deluxe 4,
    Jun 2011
    Long Beach, CA
    2,789
    Re: concentrated liquid bleach vs concentrated germicidal bleach
    If they are Clorox then the germicidal bleach is only 6.15% while the the concentrated bleach is 8.25%.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Use Regular ol' bleach. Usually concentrated is the best bang for the buck.
    The fancy bleaches such as germicadal, splashless, etc, all have additives in them that you really dont want in your swimming pool. If they are used, most often the additives will make the pool water foam up. There are many reports about it on TFP.
    Divin Dave,
    Mar 2007
    San Rafael, CA USA
    12,082
    Clorox Germicidal Bleach does not have additives that are a problem for the pool. It's "splash-less" and "outdoor" bleaches that have more excess lye and/or thickeners in them that you don't want added to the pool because they can cause foaming and excessive pH rise.
    JoyfulNoise's Avatar
    May 2015
    13,217
    See HERE for the list of ingredients from the Clorox website for "germicidal" bleach. Nothing out of the ordinary -
    Water
    Sodium Hypochlorite
    Sodium Chloride
    Sodium Carbonate
    Sodium Chlorate
    Sodium Hydroxide
    The last three ingredients occur as less than 1% each of the total solution. The interesting one to me is the sodium carbonate. It's either intentionally added as a pH buffer or it may be present from the manufacturing process - strongly alkaline solution tend to absorb CO2 from the air. Either way, nothing strange or new with "germicidal" bleach. Just a different concentration and some fancy marketing to make it sell.
    Stick to the regular 8.25% stuff and always check your date codes - I found bottles of Clorox bleach on the shelf at my local grocery store that were from December 2014
    Matt
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,777
    Lol "germicidal bleach"! Isn't that like saying "give me the wet water"?
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
