Thread: calculating di-chlor to gt CYA to 30
    I am ready to switch to the di-chlor/bleach method of sanitization.
    Just want to make sure I am figuring this correctly.
    For my 330 Gal sap, PoolMath says that 10ppm FC is about .8oz di-chlor
    Since 10ppm of FC via di-chlor raises CYA by 9ppm, I should be adding a little over 2.4 oz of di-chlor to get to the appropriate CYA level (I can always test with my TF-100).
    SO, if I set aside 1/3 cup of di-chlor (about 2.6oz), I should be able to use it to sanitize and when it's finished, I should switch to bleach. My target would be to keep FC at 5-6ppm with the bleach. but never drop below 3.
    Does this plan seem reasonable?
    TF-100 Test kit, 24,000 gal. free form Vinyl. mybluepool AC-600 SWG, STA-RITE S7MD60 DE filter, 3/4 HP STA-RITE MPRA6D pump, Polaris 280 w/booster, Raypack Propane heater, Looplock mesh cover; All located in New England.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: calculating di-chlor to gt CYA to 30
    You can check the effect of adding different chemicals by using the thing at the bottom of the Pool Math page.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Quote Originally Posted by pabeader View Post
    Cool.....didn't know that. Looks like I am right on
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    I kinda thought you were, but that tool is often missed so I took the opportunity to point it out
