Thread: Does Anybody Make an Autofill Valve that Actually Works
    Jun 2015
    Whitehouse, Texas
    2
    I can't find an auto-fill valve that works. I'm on number 3 now. They either leak even when new or the float won't hold adjustment. I'm about to the point of replacing it with a manual ball valve.
    My pool is an in-ground salt water pool. The auto-fill is in a small well beside the pool under a round plastic cover, just like a debris basket.
    Is there a high quality auto-fill valve that really works? For the cost of all the water and chemicals the valve costs me, I could afford to spend quite a bit on the solution.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Re: Does Anybody Make an Autofill Valve that Actually Works
    I've always used THIS style and have yet to have an issue...seems to work better than the toilet type of float.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    That looks like the one I have and it has been working great for ovef 3 years.
    Jun 2015
    Whitehouse, Texas
    2
    Thanks guys. I've gone through 2 of the brass ones and a plastic one that was the same style as the brass ones.
    I hadn't seen the style you suggested, so I've just ordered one like you use. Except I ordered one with a non-adjustable float. The adjustment not holding is the problem on my current brass valve. If the non-adjustable valve gives a pool level that is too far from normal then I'll buy the adjustable version of this valve like you have.
