Thread: Closing my pool in south Georgia
    Feb 2015
    Savannah GA
    21
    I apologize in advance if this issue has been addressed, but, I have been unable to find any information specific to my area. Let's face it, we do not have hard freezes down here. I normally put a mesh type leaf collector cover with water bags over the pool, run the pump a couple of hours a day and that is it. I worry about the pool again when it is beginning to warm up enough to swim again,(Apr-May). I keep all of my normal levels until the water goes down in the low 60's and then I quit monitoring it. Should I continue testing anything over the winter? Any thoughts on pump run times? I hate the power company too! Any and all advice is greatly appreciated! Thanks!
    26,500 gallons, 18X36 In ground pool with vinyl liner
    Hayward Pro Series sand filter, new sand.
    SWG, Autopilot Nano +
    3/4 HP pump running 24 hours now during SLAM.
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Re: Closing my pool in south Georgia
    Well, I'm a bit further north from you and don't close. As it gets colder the chlorine needs diminish but I still will check it every 2 weeks or so just to assure myself all is well and nothing scary going on. I also have an autocover which I open up now and then to let the pool breath. My SWG gets turned off (saves lifespan) and I dose with liquid chlorine (aka bleach) as needed.....which isn't that often. But I don't want the pool to ever sit there with out-of-whack chemistry because it can be damaging.
    When its seriously cold (those few days) we run the pump all night and cover the equipment with tarps/moving blankets with an automobile light plugged in underneath just in hopes of it helping.
    Sep 2013
    Charleston, SC
    538
    I don't close my pool either and don't cover it with anything once we are past swim season (this year, we are still swimming with the solar cover!). I test every couple of weeks for FC and PH and monthly for TA and CH and only test agin for CYA when my water gets above 60 and also turn my SWG off and manually dose with chlorine as needed.
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    Feb 2015
    Savannah GA
    21
    Thanks for the advice! I really did not consider turning off my SWG to preserve it's life! That is very good advice and the reason I ask questions! My thanks!
