Thread: Northern VA recommendations?
    Jan 2010
    Northern Virginia
    282
    I'm posting this for a friend who will be joining the site soon.
    Does anyone have a recommendation for a good pool builder in the Northern Virginia area?
    We used Anthony and Sylvan and I was not happy with them at all.
    Thanks!
    Bart
    700 sq. ft./30,000 gal, gunite pool; 48 SF DE filter; 1.5 HP pump; Salt Water Generator; Solar Heat
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Northern VA recommendations?
    Did you get multiple bids and visit with multiple contractors?
    I'm obviously not from the area and can't throw out a recommendation, but getting multiple contractors to bid on the pool and discuss options is the best way to get a feel for the contractor and how well the process will go. That combined with your experience with A&S should be a good start.
    Isolated Spa - 345 Gallons
    Jan 2010
    Northern Virginia
    282
    The JVT.....I didn't.............I took the recommendation of a friend who was happy with them.
    I'll pass that tip along.
