Results 1 to 7 of 7
Thread: Pool Pump Motor Shutting Off
    Oct 2015
    Friendswood
    4
    We have an Aqualogic saltwater system with an emerson pump motor. The motor shuts off on its own before the timer expires, sometimes after an hour sometimes after 10 minutes. If we engage service mode and turn the pump on it stays running and doesn't shut down which leads me to believe it is not the thermal protection on the pump motor as originally thought. At the control panel the voltage in and out for the pump is good too (when it is running).
    Do I need to trace out a relay that may be bad or any other thoughts?
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: Pool Pump Motor Shutting Off
    How long had the system been in service?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Oct 2015
    Friendswood
    4
    Quote Originally Posted by pabeader View Post
    We only put it in service to see if the pump would shut off due to thermal protection, but to answer the questions it ran for 24 hours in service without shutting off.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Oops! My bad choice of words!!! I meant, how long have you had the equipment.
    Oct 2015
    Friendswood
    4
    To be honest I don't know the age, we just purchased the house in July. Looking at the appraisal district records it looks like the pool was built in 2006 so I would imagine it is still original equipment.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Sounds like the control panel might be in need of service. Sometimes it's just dust and dirt and a good blowout with an air compressor does the trick. Maybe a few pics would help.
    Oct 2015
    Friendswood
    4
    Here are pics, it is pretty clean inside the control box
