Results 1 to 11 of 11
Thread: New North Texas Pool
    Oct 2015
    Texas
    5
    Absolute Pools 3.jpgWell we're making the plunge (pun intended) and purchasing a new in-ground pool. We recently accepted a bid and expect on signing a contract next week. Here are the details regarding equipment, pool size, etc. Please feel free to offer up some suggestions.
    100 PERIMETER SWIMMING POOL/572 SQ. FT/5 DEEP
    STEPS WITH TANNING LEDGE
    2 LOVESEAT
    1 SHEER DESCENT WATERFALL
    DEPTH: 36 5
    REBAR:
    STEEL ON 10 CENTERS-5 IN STRESS AREAS
    BEAM WITH 4 BARS
    ALTERNATE BARS THROUGH THE BREAK
    PLUMBING:
    DUAL DRAINS IN POOL
    2 SKIMMERS IN POOL
    2 SUCTION / 1.5 RETURN
    7 RETURNS
    1 CLEANER LINE
    PRESSURE TESTING
    1 WATERFALL LINE FOR SHEER
    FILL LINE TO HOSE BIB
    ELECTRICAL:
    POOL COMPUTER WITH REMOTE
    1 JANDY LITE WITH NICHE
    BONDING OF POOL, DECK, LIGHTS, AND ANY OTHER METAL ITEMS
    GFCI PROTECTED LIGHTING
    GUNITE:
    8 TO 12 6 SACK MIX
    100% NATURAL SAND MIX
    3 YEAR LIMITED WARRANTY
    NO REBOUND IN POOL
    TILE, COPING, AND STONE
    6 WATERLINE TILE
    STONE COPING OR EQUIVALENT
    60 SQ. FT OF DROP BEAM VENNER
    46 OF DOUBLE COPING
    DECKING:
    1200 SQ. FT. OF CONCRETE
    CUSHION SAND BASE
    3.5 TO 4 THICK
    3/8 REBAR ON 18 CENTER
    TAN DECK-O-SEAL MASTIC JOINT
    PLASTER:
    WHITE PLASTER INTERIOR FINISH
    POOL EQUIPMENT: (3 YEAR PARTS AND LABOR ON JANDY, POLARIS, AND ZODIAC)
    2.0 HP JANDY STEALTH
    460 CARTRIDGE FILTER
    1 JANDY POOL LIGHT
    6614 JANDY POOL COMPUTER
    PENTAIR INLINE CHLORINE FEEDER
    POLARIS 280 POOL SWEEP WITH BOOSTER PUMP
    2 SHEER DESCENT WATERFALL
    TAYLOR TEST KIT
    POLE, BRUSH, RAKE
    ADDITIONAL ITEMS:
    PEBBLE INTERIOR FINISH
    FIRE PIT ADD
    CONCRETE AT PIT ADD
    SALT SYSTEM
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Re: New North Texas Pool
    Congrats...love it..I want it!
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Aug 2014
    Houston tx
    2,525
    Welcome to TFP! Looks like a great pool! I'm sure someone will be along shortly to make suggestions on your equipment and such. I did notice you only had one light tho. Since I didn't see the dimensions of your pool I can't really say but I think you might want another.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Mod Squad pooldv's Avatar
    DFW, TX
    24,512
    I would add a bench to the bottom edge of that rendering. Benches are great for sitting and sipping beverages and kids love to use them as home base.
    Get at least a 2 speed pump or even better a variable speed pump. It will dramatically reduce your energy consumption. I run my VS pump 24x7 when the trees are busy during spring and fall for less than 12 bucks a month.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,620
    I like the set up with the fire pit towards the back.
    Do you have any kind of overhang for shade back there? You are going to need quite a few umbrella holes.
    Kim
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Looks beautiful! Stick around, you'll get great advice, and Kim will help you spend your money! Welcome!
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    Oct 2015
    Texas
    5
    Quote Originally Posted by Marlahoutex View Post
    Thank you. We talked to a few other people who've use our PB and they also suggested 2 lights. I believe we are also going to upgrade to a multicolor light system as well.
    Oct 2015
    Texas
    5
    Quote Originally Posted by kimkats View Post
    Kim
    The render of the tree is a little misconceiving. It's a pretty good size tree and should provide adequate shade for the fire pit and pool area. Unfortunately, it will also provide an adequate amount of leaves for me to clean out of the pool. Also, the rendering doesn't depict a pergola that is located in the U-Shaped section of the house. Thankfully shade shouldn't be an issue.
    Quote Originally Posted by pooldv View Post
    Thank you. I will definitely talked to the PB about a 2 speed pump.
    Oct 2015
    Texas
    5
    Jul 2012
    Tallahassee, FL
    30,620
    Will you keep the hot tub? What fun you are going to have with that area!
    Kim
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    I would suggest going deeper if you can. That pool is pretty shallow and in the Texas heat will feel swampy warm by mid summer.
    And a deeper pool is easier to swim in. Some folks have complained about brushing knuckles on the floor of shallow pool....and well...cannonballs are just a LOT more fun in a deeper pool
    Just *my* opinion of course.
    Yippee
