Thread: Noisy Spa pump/motor (with video)
    Fountain Hill, Arizona
    37
    Hello,
    The other day, I noticed that my spa sounded really loud. Please see video here:
    Noisy spa - YouTube
    The manual says to "Clean the suction" and/or "Open both valves", but I'm not quite sure what that is.
    From the above video, does anyone know what the problem is? Do you think it is the bearings, motor, belt or maybe I need to "lube" the "O" rings???
    If anyone has any advice or can help, I'd greatly appreciate it.
    Thank you so much in advance.
    In-ground 18000 gallons salt water pool, sand filter, 4-5 feet deep, kidney shaped small pebble tech pool with water feature.
    beachinmoney's Avatar
    Jun 2013
    Buckeye, AZ
    159
    Re: Noisy Spa pump/motor (with video)
    You might want to post the make, model, any additional information. That will help.
    Beachinmoney, live in AZ, Pool is inground approx. 14,500 gallons of water. I have a Pentair Intelliflo 2 VST pump. The pool was built in 2006 and Pentair Clean and Clear Plus Filter System. A&A in-ground cleaning system
    37
    Thank you for your reply beachinmoney (Sorry for not responding sooner, I was out of the country).
    I've added a photo of a close up of the pump with the model number and whatnot.
    SPA PUMP MODEL - Imgur
    It looks like a Smith? - Model # MF5-23030 P4-MT?
    I've also taken a new video (closer up) and I'm not sure if the noise is coming from the fan/pump (the RED thing on the left) or the motor thing on the right (BLACK)?
    Spa pump close-up - YouTube
    Thanks again in advance to anyone who can help me out.
