Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Outdoor TV
    Oct 2015
    Burleson, Texas
    178
    Outdoor TV
    Anyone have a tv mounted outside? I really don't want to spend 2K for an "outdoor" tv. I read that the biggest killer of tvs is heat. I know they make covers and it would be under my back patio which is protected from the elements. I was thinking if I've got to drop a few hundred bucks every few years in a tv that it wouldn't be that bad. You can get tvs so cheap now I can't see spending the cash on one made for outdoors. Opinions?
    21,000 gallons, Salt, IG Gunite, Plaster Finish, Free From, Pentair FNS DE cartridge filter, Pentair Intelliflo-VS pump, Intellichlor IC-40, 2 port fountains, bubbler in tanning deck, Dolphin M400, TF-100, K-1766, Speed Stir
    Mar 2014
    Angleton, Tx
    91
    Re: Outdoor TV
    I have a buddy that has one mounted outside. The first tv he always kept it covered, i think it lasted 6-9 months. The issue he found is that with the cover on all the time is it wasn't breathing and holding in moisture (it gets humid here). He now just keeps it uncovered unless there's gonna be heavy rains or what not and this one has lasted yr and half so far.
    IG Pebble sheen blue surf approx. 14k gallon, beach entry, 7' spa, 3.5 ton jumping rock/waterfall, Pentair 2hp whisper flo, booster pump, 520 cartridge filter, Stenner Econ T, 400k master temp heater, easy touch controls,TF-100 w/speedstir
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Outdoor TV
    I'm on my second house with a TV mounted outside. The first was in the DC suburbs and my current house in SC. I just build a box to keep,the rain off and I've never had a problem including with snow on the ground.
    Support the site
    Oct 2015
    Western Australia
    35
    Re: Outdoor TV
    Ive always just used a cheap TV and never had a problem.. but Its pretty dry air where I live.
    16000 Gallon In Ground Fibreglass Pool, Chloromatic ESC24PH SWG + auto Acid doser, Enduro EN-850 Sand filter Austral E Series 290 1.50hp pump, Poolrite EP1100 1.5hp Solar Pump with Aquatight V2D deluxe Digital Solar Controller, Pool Estimate build date around 2008. Taylor K-2006 test kit. Pool is filled via rain water as scheme water is not available.
    JcSparky's Avatar
    Aug 2014
    Baton Rouge, LA
    18
    Re: Outdoor TV
    In south Louisiana, I've had a cheap 32" Dynex HD (Best Buy) mounted under my back patio for 5 years now and still works like a charm. It's mounted high enough under the over hang where it never get's wet. I do not cover it at all. Had doves nest behind it a couple of years and never had a problem.
    11,500 Gallon IG Blue Hawaiian Vista Isle Fiberglass Pool (January 2015), LED Light, Jandy AquaPure Ei SWG, Jandy FloPro 1.0 HP Single Speed Pool Pump, Jandy Pro Series Sand Filter - Top Mount - 22", Polaris Vac-Sweep 280 pressure-side pool cleaner, Polaris PB4-60 Booster Pump, Jandy Never Lube 3-way Valve, Brushed Concrete Coping and Deck, Taylor K-2006 Test Kit, Taylor K‑1766 Salt Water Test Kit, SpeedStir
    rajung's Avatar
    Mar 2015
    Iowa
    185
    Re: Outdoor TV
    Same flat screen for 3 years.Take down around mid , late October.
    Put back up in April or when the weather permits to sit outside.
    Mounted just under edge of eave of roof covered, open deck, about 2 1/2 feet back from gutter.
    Cover with a flat screen cover only when high winds and rain expected, only rain, no I don't.
    Not worth the thousands in my opinion to get a TV that will be out dated that is expected to last for many years outside.
    I was close to buying one myself, glad I chose not to.I can buy 10 of these and be ahead and have the most current tech. options and not something 10 years old and trying to save. due to initial cost.
    Doughboy AG 16' x 32' oval, 13,700 gal.
    AquaView by Doughboy 150lb sand filter model 0-1709-20
    PowerLine pump by Doughboy model 0-3047-200, 1.5hp-single speed-20amp
    Gulfstream electric heater-HE125-R-A
    christied48's Avatar
    Aug 2013
    Allen, TX
    89
    Re: Outdoor TV
    We move the 50" smart TV from living room to patio all the time. We leave it out 3-4 days a week during summer, covering it with the foosball table tarp at night or if its going to rain.
    Put a full motion tilt mount on middle of wall under the patio and figured out a quick release where we undo a few screws and take it off with part of the mount still on the back. The other 1/2 stays on the patio wall. The TV then goes back on a stand in living room.
    Its very quick to do.. so it goes back and forth alot for about a year now. TV still works great inside and out!
    24K gallon IG Stonescapes, Jandy VS pump, cartridge filter
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Re: Outdoor TV
    My cheap tv has been on the wall of a covered patio for over two years with no issues. We even had baby birds behind it this spring. As soon as they left I cleaned it out and keep it clean now. Mama bird is back and yelling at me for messing up her stuff! The TV was probably 5 years old before we moved it outside. Wireless directv and chromecast make it all good.
    May 2015
    Gulfport, MS
    109
    Re: Outdoor TV
    Can anyone post some pictures of their outdoor tvs, preferably ones where they had to build something to protect them from the elements.
    12X20x54" Saltwater 8000 semi-inground, Waterway 1.5hp 2speed 22" Pump Sand Filter, Hayward Goldline Aquatrol HP SWG, TF100
    DFW, TX
    24,468
    Re: Outdoor TV
    Mine is under a patio roof and left open. But, a friend has his on an exposed 2 story brick wall and he uses a BBQ grill cover on it when it is going to rain. It's been out there at least a couple of years.
    Aug 2013
    Allen, TX
    89
    Re: Outdoor TV
    Well if you set it pretty far under the patio, don't need to enclose it, really. They do make nice TV covers but a foosball tarp or BBQ cover works too. This TV is not in the corner but it swivels over...
    Aug 2013
    Allen, TX
    89
    Re: Outdoor TV
    Only pic I had.. sorry I had a bunch of stuff on the porch still from a Saturday party.. chillin on a Football Sunday.
    Dec 2014
    Cypress, Texas
    200
    Re: Outdoor TV
    For any of you that have the TVs outside, what do you do for sound? Do you have some external speakers hooked to the TV? Just use the TV speakers?
    2016 Build: 32x8 Gunite, 6,700 gallon IG pool including 6x8 spa and 6x8 tanning ledge w/ 2 bubblers. 32' raised wall with two sheer descent water features. Travertine Coping w/ split faced Travertine on raised wall face. 2HP VS Jandy pump, 400k heater, Rainbow Chlorinator, 4 Colored LED Lights. 459sqft spray deck plus. IAqualink remote, Polarus 9350 Robot Cleaner.
    Aug 2013
    Allen, TX
    89
    Re: Outdoor TV
    We already had 2 speakers hardwired under porch so we just got a bluetooth capable receiver and ran wire on top of fence for 2 more speakers around pool. Can play TV, pandora, ipod, radio or phone music and can change from 2 or 4 speakers as needed.
    Couldn't afford Sonos right now but like that best. Could have got wireless for the poolside speakers too but these outdoor ones work great as it is.
    Aug 2013
    Allen, TX
    89
    Re: Outdoor TV
    JcSparky's Avatar
    Aug 2014
    Baton Rouge, LA
    18
    Re: Outdoor TV
    .. we simply use the speakers from the TV (32" Dynex) which is loud enough from several yards away, although speakers out by the pool would be nice.
    Oct 2015
    Burleson, Texas
    178
    Re: Outdoor TV
    I'm hoping to find a way to Bluetooth to my stereo receiver in the house so I can use the JBL speakers on the patio. I did see that WalMart will have a black Friday sale and you can get a 40" for $149 and a 50" for $249.
    Nov 2015
    Chicago, IL
    7
    Re: Outdoor TV
    Quote Originally Posted by tim5055 View Post
    My friend also has a TV on his patio with a box, and he hasn't had any problems. I would recommend mounting the TV to the outside of your house in the most covered area and getting an attachment so it can swivel to where you want. The more cover it gets, the better.
    DFW, TX
    24,468
    Re: Outdoor TV
    We have SONOS. A Playbar in the living room puts TV sound into the SONOS system and then we can broadcast TV sound to all SONOS speakers inside and outside.
  20. Back To Top    #20
    Nov 2015
    Chicago, IL
    7
    Re: Outdoor TV
    Quote Originally Posted by pooldv View Post
    How do you like your SONOS system? I've heard good things but haven't taken the plunge yet.
