Thread: Small leak at light
    Mar 2009
    Woods of North Florida
    Small leak at light
    We had our pool installed less than two weeks ago (above ground pool). The installer cut the liner and put in a small light. I noticed today that there is a little bit of water dripping down the outside liner from the bottom of the light. I'm going to call the installer but wanted to have more information before I make the call. What should I be most concerned about? Is this normal? Could this turn into a larger leak? I guess it is like a small leak from your will add up over time. Thanks in advance for any suggestions/comments!
    24' Seaspray Evolution CLX Above Ground Pool (~13600 gallons)
    Pentair Sand Dollar SD60 / 22.5" filter / Maximum Flow Rate 60 GPM
    Pentair Dynamo Pump 1 1/2 HP
    Re: Small leak at light
    Not exactly normal, no. It should not be leaking. On the other hand it does happen now and then.
    It should be fine in the short run. Just make sure it gets fixed. Long term it could cause the panel and/or frame to rust out (if either of them are metal, which they usually are).
