Results 1 to 11 of 11
Thread: How important is Calcium Hardness in Fiberglass Pool?
    Oct 2015
    Perth Western Australia
    9
    Hi All,
    This is my first post, looks like a great forum. I have read some parts of the forum and was convinced to get a good test kit rather than going to the pool shop thus I have acquired my own personal test kit. So after doing doing the first run (result accuracy may be a little off till I get the hang of it) I measured
    pH 7.4
    CH not detected (in the 2 stage test the first stage indicated no CH)
    FC 2.0
    CYA 30
    TA 40
    and using a cheap digital TDS meter 1500.
    Before I added anything to lift the calcium hardness I wanted to establish why as what I have read focuses on impact on cement and plaster based materials.
    Geoff
    Fiberglass
    55,000l inc spa
    Chemigem Liq Chlor & Acid
    Blanket & Solar Heating
    Media Filter with Glass
    Aug 2014
    Northern IL
    4,615
    Re: How important is Calcium Hardness in Fiberglass Pool?
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    880
    Hi Geoff,
    Welcome to TFP! I'm just down the road in Bunbury.
    CH is more critical in cement/plaster pools as it protects the calcium in the pool surface from pitting. Some fibreglass pools are made with a gelcoat which also has calcium carbonate and therefore to a lesser extent it needs to have CH added as well. This is the case with my fibreglass pool. Can you find out whether your pool has a gelcoat by contacting the manufacturer?
    Also your FC level is on the minimum level for your current CYA level and if you let it drop much lower than you will risk an algae outbreak especially now that the weather is warming up here. So maybe get it up to around 5 for that level of CYA but you will want to get your CYA up to about 50 in due course. I would monitor your pH by testing daily as your low TA may cause it to fluctuate and you certainly do not want your pH levels to go outside the recommended levels. I'm assuming that your Chemigem isn't the model with the pH auto feeder.? Read up on Pool School and this will give you a really good grounding.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    Oct 2015
    9
    Oh thanks for the quick replies.
    @Jezza Hi neighbor.
    The pool is ~15 years and made by Buccaneer. I assume was typical gelcoat/cloth resin construction. I'll just target the recommended level in MarianParoo's link.
    Just starting to look at pool for this summer, the desired chemicals seem to dilute with the winter rains.
    The Chemigem does both chlorine and acid dosing, though I have found the sensor is prone to inaccuracy with foreign matter catching or building up on the probe and I usually give it a rinse in acid this time of year.
    Fiberglass
    55,000l inc spa
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,080
    As mentioned above there are a few times that calcium is needed in Fiberglass pools, so to play on the safe side we suggest maintaining 220-320ppm calcium in the water to avoid any issues. Unfortunately I do slightly question the Australian test kit you have purchased as it's somewhat unlikely you have zero Calcium in your water. Can you please explain to us what you see as your preform this test? If you do start to add any calcium based on this kit I would HIGHLY suggest you tiptoe to your "goal" and only add a small amount at a time. It's FAR easier to add calcium than it is to remove.
    Sep 2013
    Charleston, SC
    537
    Quote Originally Posted by Geoff2005 View Post
    Geoff
    Calcium can also be part of keeping your CSI at the correct level. I too have a fiberglass pool and to keep my CSI where I want it, I have to increase my Calcium to 300 and raise my PH to 7.8 to balance keeping my TA at 60 so i don't have PH creep. It really is finding the "sweet spot" that your pool likes and each pool is unique.
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I'm obviously not familiar with that water, but it is very unusual for most water in the work to be free of calcium. Hardness can vary wildly, but none is very rare.
    May I ask what you mean by the first and second stages of the CH test Geoff?
    Essential Links:
    Oct 2015
    9
    Hi All,
    Thanks for the further feedback on CH in relation to Fiberglass Pools.
    Re CH test.
    Test kit instruction said add drops in first stage and sample will turn orange indicating calcium, my sample was more like purple/black after adding stage 1 so I didn't bother adding stage 2 reagent.
    I see here though the instructions may be wrong Aussie test kits and hello.
    So I will try test again with different target colours.
    Fiberglass
    55,000l inc spa
    Oct 2015
    9
    Just redid CH test, I see it is 3 step not 2 as I had recalled, I just didnt do last step as colour was not orange.
    Anyway redoing and using change from red to blue (not orange to green as per instruction) I got a result of CH = 125.
    Fiberglass
    55,000l inc spa
    Sep 2013
    Charleston, SC
    537
    You might also look at this thread Newbie From Perth Western Australia. - Page 3 post 50 as there might be an issue with the test kit (if you have the same one).
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Orange to Green would be a TA test. A CH test should always be Pink/Red to Blue/Purple. I'll check the links, and may post back afterward.
    update:
    It seems like they are really careless putting this together after seeing the other thread. TA test instructions for Calcium. That's an unacceptable oversight in my opinion. Wow.
    Essential Links:
