Results 1 to 9 of 9
Thread: Re-plaster and pool start-up: delay?
    Oct 2015
    portland oregon
    2
    I'm about to do a pool replaster for my brother in Dallas. Everything I have read indicates that it is a good idea to delay filling the pool with water after the replaster for at least six hours, and preferably 24 hours.
    IS there any reason not to wait for 2, or 3 days, or a week, or two weeks, to fill the pool after the plaster has been put on? Everything I have ever done with Portland cement based products indicates a very long cure time. Why is it a bad idea to wait a week or two to begin filling the pool and give the plaster time to cure?
    Any feedback would be helpful.
    Thanks
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,464
    Re: Re-plaster and pool start-up: delay?
    Pool School - Start-up New Plaster
    I hope this link helps you.
    I have not seen any pools where they did not fill right away. In fact as soon as the acid wash is done they have the hose in to start the filling.
    Kim
    Aug 2007
    near the swamp
    806
    the plaster could dry out and start cracking, so it needs to cure under water
    Oct 2015
    Pentas/TX
    28
    Quote Originally Posted by Do it myselfer View Post
    Thanks
    Any links that mention waiting to fill after the plaster? I've seen some builds that wait till next day, but usually they are pebble plasters. I did quartzscapes (blue) and when the plaster hardened I did acid wash within two hours. Immediately started filling after the acid wash. If I recall correctly, Diamondbrite specs suggest a time, but also state to get a good feel of how the plaster is curing. Once dry, or hard, then move one is what it says. Quartzscapes doesn't have anything in writing, I even called them directly so I did everything based on the feel of the plaster. I wouldn't wait more than 24 hours, especially if your in a hot zone.
    40x20 Rectangular (3'to6' depth),Cantilevered Deck, Whisperflo 2HP FullRated, DE 60 SQft Filter, 2 Intellibrite 12V 5G Color Lights, Intellibrite Controller
    Oct 2015
    Austin, TX
    83
    Our Pool Builder (Cody Pools in Austin) were very careful about this part of the schedule. Plaster/Pebble one day, acid wash the next, then start filling immediately, preferably with 2 hoses.
    Pool: 16,000 gallons, 16x31, 500SqFt gunite pool, White Pebbletec interior, built by Cody Pools. Pentair Intelliflo VS-3050 pump, Pentair Clean & Clear 420 Cartridge Filter, In-line chlor with Ultra UV, PV3 Infloor cleaning, Pentair Easytouch-P4 control. TF-100
    Spa: 525 Gallons, Coast fiberglass spa of unknown vintage and suspect previous care with a 2-speed main pump and a blower motor, both 4HP. 3-step bromine sanitized.
    Jul 2011
    Arizona & California
    803
    Portland Cement does cure and hydrate for many years. However, it is best to allow curing to take place with plenty of moisture available so that it doesn't dry out.
    Cement (and pool plaster contains a lot of cement in the mix) also shrinks when drying takes place. Therefore, it is best to cure underwater, but only after a sufficient amount of time to allow the immediate surface to harden properly. To do that generally requires at least 6 hours to a maximum of 24 hours depending on temperature and humidity. The higher the humidity, the cooler it is (as long as it isn't freezing), the longer you can wait.
    Many plasterers are afraid of the plaster cracking due to drying out, and therefore, start the water immediately after finishing. But that is not the best practice. Waiting six hours is not going to make a significant difference. If the plaster mix is thick (with a low water to cement ratio), and with no water troweling, and no calcium chloride added, then the chances of cracking are very minimal. Placing a tarp over the pool is also a good practice in hot and dry weather to prevent cracks.
    Aug 2014
    Northern IL
    4,615
    I understood all but this sentence: Waiting six hours is not going to make a significant difference. Thanks, Lisa!
    Oct 2015
    portland oregon
    2
    Quote Originally Posted by onBalance View Post
    Thanks for the wisdom! It sounds like the main danger for waiting is that drying 'plaster' (cement) could shrink and crack. Anyone know of other reasons not to wait longer? By the way, OnBalance, I love all the work you have done to bring science and rigor to the pool plastering industry, and the rigorous science you bring to the complex chemistry of concrete curing. Assuming one could control cracking (by using dryer cement, slowing cure times, waiting for humid/cool days, using acrylic/other additive?) is there any reason not to wait 2,days, or a full week for filling? I know you have done experiments with 0, 6 hour, 24 hour, etc- but have you looked at a full 7 day cure for pool plaster?
    Also, some people say that you cannot work a plaster seam that is setting up with freshly applied plaster- is this an aesthetic issue, or would it create water-permeable seams? For example, if I plaster a portion of the pool, and then work back so that a wet line of plaster is abutting a portion that is an hour or two old, would that be a problem? I know it won't feather out very pretty, but won't the 'green' plaster and the fresh plaster still form a chemical bond, rather than a seam? I'm asking because I am working alone, and can't use a pump to spray and trowel the plaster fast enough. Thanks in advance for your advice. (I'm not planning on using any accelerators, using very dry plaster, and possibly adding a bonding and/or anti-shrinking additive.)
    Jul 2011
    803
    If it rains, that causes etching of the plaster surface - because "rain" is very aggressive.
    The plaster can be stained due to dirt, leaves, etc.
    If the plaster cracks, it also can delaminate (bonding failure) from the substrate beneath. This issue would be very likely by not filling within a few days.
    Waiting just six hours to start filling with water would not make enough difference to cause cracking problems. It usually takes 24 to 48 hours to fill most new plaster pools anyway, and six hours more is not a major difference.
