Thread: Closing the pool, leave the spa operational
    HI, Im here in NJ, and we like to use our spa through Dec/Jan, but obviously not the pool. We usually cover the pool, leave everything on, and just flip the cover back on the spa when we want to use it. This obviously can be a pain, since we have to close the pool in Jan, and the water is devastatingly cold to put your hands into.
    Is there some way to shut down the pool, lower the water level, chemicalize it etc., but still be able to use the spa and have to shut that only down in January?
    Thanks for any help!
    Anne Marie Menges
    33000 gal saltwater unite pool
    attached overflow 8"diameter spa
    Anne Marie, Monmouth County ,NJ. Salt water in ground french grey quartz/gunite pool 25000 gallons install July 2012
    Jun 2015
    Wildomar, California
    423
    Re: Closing the pool, leave the spa operational
    Yes, it is possible. When I lived in E.Pa I had some customers do this. But, the spa must be able to run totally independent of the pool and the spa would have to be run 24/7 to prevent freezing issues. Making sure that there is no exchange of water between the spa and pool is the key. Some pictures would be good for me to advise you more, or for another expert to chime in
    wjr75's Avatar
    Jun 2013
    IL
    836
    We have our pool closed the first week of October and keep the spa open until early December. I have a pool company do it for us so they winterize the pool closing all the return valves after blowing them out. They do some changes to the auto control wiring and auto valve settings. As mentioned above all the pumps need to run in freeze protection once the temps drop below freezing.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
