Thread: Installing additional return line
    Oct 2015
    McDonough, GA
    5
    Lightbulb Installing additional return line
    Installing a used 18X33 above ground pool. Current skimmer and return line are at one end, just off of the straight wall. Wouldn't adding another return line at the other end help with circulation for filtering and chemical distribution?? I will be constructing my own lines for the filter and returns. What are some considerations for placement and configuration?
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Installing additional return line
    Maybe, Maybe not. It depends on the equipment you plan on using specifically the pump and filter.
    Mark
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    My skimmer & returns are on the same side.
    When i change my returns eyeball to this type it made all the difference in the world
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Oct 2015
    McDonough, GA
    5
    I can see that directing the water flow away from the skimmer. But I'm wondering about circulating the water at the opposite end of the pool. With one return, at the same end as the skimmer, it seems the water at the other end wouldn't move very well.
    SeaSpray High Sierra 18X33 AGP - 15,700 gallons - Hayward DreamLine sand filter S190TSCP 45GPM - Hayward Power-Flo LX 1.5HP 70GPM - Liquid chlorine and baking soda
    mas985's Avatar
    Pleasanton, CA
    11,741
    You will be surprised at how far the flow rate out of a return reaches especially with the pump you have. Here are some experiments that I ran on my pool. One of the videos is with a single return.
    Circulation Dye Test
    Skimming is likely to be more of an issue than circulation but again, unless there is a really good reason to add the return now vs later, I would just see how the pool performs as is.
    Mark
