Thread: Auto Fill Fitting Help
    Jaimee's Avatar
    Jun 2014
    Queen Creek /Arizona
    42
    I made my own auto fill out of an 8" pipe piece and a toilet float. It is working fine. (I still haven't plastered yet.) But I don't know what fitting to put on the 3/4" pipe inside the pool. A smooth coupler? A filter grate fitting to keep out bugs or debris? Nothing? I need to cut the pipe but want to leave clearance for the correct "thing". Any ideas? What do you guys have on yours? This seems like a silly little thing, but it's hanging me up. My internet searches are coming up blank and I'm starting to have bad dreams about it.
    Building
    4.5K gal in-ground, 876 gal spa in-ground
    negative edge, raised perimeter, 4' depth
    limestone coping, fine pebble plaster with abalone shell, sand filter, propane heater
    My pool build thread: 91265-Jaimee-s-Owner-Builder-Pool-AZ
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Re: Auto Fill Fitting Help
    Standard return fitting?
    Return Fitting
    You'd probably need to adapt from your 3/4" pipe to a larger size (1" or 1.5" or 2" PVC) because most return fittings are 1.5" or 2", although I saw some online for spas that are meant for 1". Couldn't find anything that direct connects to 3/4" pipe.
    Last edited by gtemkin; 10-28-2015 at 11:24 AM. Reason: Add photo and additional info
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Jul 2015
    Central Valley CA
    1,109
    Nothing is certainly an option just cut it flush and sand the edge a bit, I have seen one like that and since it is 3/4 most people won't even see it. They are plastering my pool tomorrow and are using the same fitting as the returns but mine is 1.5”. Bugs and debris should not be much of a concern since it will be below the surface. If it does get a bit gunky from time to time, just scrub it out with a toilet brush blast it out with the hose add a bit of bleach and call it good.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Kinda hard to tell from the photos, but is that plastic or metal pipe?
