Page 1 of 2 12 LastLast
Results 1 to 20 of 36
Thread: PB knowledge levels.
    philboyj's Avatar
    Jul 2015
    Houston TX
    326
    I was speaking to a PB today regarding a quote they gave me for building a pool in Houston. I was asking him his opinion about water chemistry and salt water pools and use of trichlor pucks etc.
    I was a little surprised at their remarkable lack of knowledge even though they are in the business.
    For e.g. : Me: what do you recommend the free chlorine level to be at when using SWG..
    Answer: Nope...I'm not that much into water chemistry.
    Me: What is your take on the increasing CYA levels using trichlor pucks?
    Answer: haven't heard of anything like that.
    This PB quoted in excess of 100k to build a "pool" only. No kitchen, no landscaping, no pergolas or covered structures.
    My question is: Is it reasonable to expect a PB ( that too the owner) to have in-depth knowledge of these things or am I asking for too much?
    Geometric pool with all Pentair equipment. Raised spa - 18" with Artic Lagoon 1" glass tiles. 3HP VS Pump, 2 skimmers, 6 returns, IC40 Salt system, Easy Touch 8 with LED color light in pool and spa. 1200 sqft of Marble White Pavers decking in Versailles pattern. Tiling and coping almost completed, Indigo Blue Prism Matrix plaster. Pool Build Thread: Houston (Katy) Pool Build - Started April 2016
    Apr 2013
    Sacramento, CA
    2,769
    Re: PB knowledge levels.
    Frankly if you were actually talking to the owner of the PB and he doesn't know much about pool chemistry that tells me he is a construction guy and a very small PB.
    How many pools did he build last year? He would be too small to entrust with a $100 K job.
    There are many different kinds of pool builders. There are large fully integrated companies that build and service pools. There are small one man shops that sub all the work out and do no service work. And there is everything in between.
    You should get three bids on the same plans. From three companies. At least one should be a large integrated pool builder that does most work in house. At lest one should be a small high end custom pool builder. Talk with them about what you want and listen to their suggestions. Then give them a general drawing and some specs and ask for a bid. The bids won't be exactly the same in what they are bidding on but they will be close enough. Let them know you are putting the job out to bid.
    If the PB is a small guy who got his start in construction he probably has no pool at home and doesn't know service. Does he build great pools? Maybe. But are you going to gamble your $100K on a guy who runs a pool company and doesn't have the ability to hold his own with a two week trainee at Leslies?
    Killer95Stang's Avatar
    Sunny SoCal
    591
    Your best bet is do all the research you can about water chemistry and become your own expert. Pool builders make money building pools, period. The questions you ask about salt water, or specific chemistry should only relate to the warranty that is offered. My pool builder had a crew that did all the concrete work, and that was their specialty. Everything else in the pool build was subbed out to "experts" in their respected fields. Electrician came in and did his work, tile & stone guys came in to do their jobs and the gunite crew did a great job doing the shell.
    During the quoting phase I also learned that even the biggest builder in CA (CA Pools) uses subs. So, you can look at it in as two trains of thought. You employ multiple crews throughout the year (even on the off season) with a huge overhead and/ or end up with "jacks of all trades, but masters of none." Or, you have a good group of guys that can do all the heavy lifting, then use a well trusted group of subs (experts) to complete the detailed work of each particular part of the build.
    Your best bet will be to go look at pools that are a few years old that were built by your prospective PB, then ask him the loaded questions about specific aspects of the build. Water chemistry is independent of the build and will be the same whether you are dealing with a bird bath or swimming pool.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    The beauty of TFPC is once you learn the basics, you know more about water chemistry than 99% of of the people you meet. That includes anybody, PBs, pool $tore employees, pool boys, and the average pool owner.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    You are expecting too much. Most PB's build pools. For the most part, they dont own or maintain pools.
    Additionally, you are posing questions about the pucks adding CYA, etc, The people who are in the pool water maintenance business, do not recognize the issues that come with that. The CYA/FC ratio is not taught in CPO classes.
    This is why TFP disagrees with the method of pool store maintenance, and this is why TFP exists to begin with.
    Quote Originally Posted by philboyj View Post
    Sent from my SM-N910T using Tapatalk
    Divin Dave,
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    I'd want my PB to build a good pool. I don't give a hoot of what he knows about water chemistry. Without TFP, different story.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    I wouldn't expect a PB to know much about chemistry, especially not the TFP methods. That said, I wouldn't really care either. Being good at pouring concrete, plumbing, and plastering can certainly be exclusive from knowing the FC/CYA relationship.
    Our PB has a deal with a pool care company (solo guy in a van) who comes out for free to do startup/owner education in hopes that you'll contract him for closing/care work down the road (we didn't). He advocated using test strips, 1-3ppm FC regardless of CYA, and told us to Shock our pool at least once a week and before/after high swim loads. I was told drop tests are too expensive and complicated unless you are a pro. He came back a month later to add the salt, and told me my FC was "dangerously high" at 6ppm.
    Needless to say I am very thankful I found this website.
    $100k sounds high, but I guess it could depend on your location/design of the pool. Our 28k IG gunnite build came in at around $58k.
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    Mar 2013
    New Hampshire
    351
    Not a chance I would expect my pool builder to know those answers. They built a great pool however....
    18k: IG: Black Granite Liner: Aspen: 16x33.5: SWG: Polaris 280
    My pool build new-pool-build-in-nh-t60957.html
    philboyj's Avatar
    Jul 2015
    Houston TX
    326
    Quote Originally Posted by gwegan View Post
    Hi gwegan. Thanks for your input. Not sure if anyone in Houston does most of their work in-house. If other forum members knows of any, please let us know.
    Thanks again
    Quote Originally Posted by bmoreswim View Post
    You hit the nail on the head - " Without TFP, different story" - I believe 90% of pools are being built by clients without TFP knowledge. This is exactly why I feel PB's need to know this. At this rate we will be dumbing down PB's "must have" skills to being able to pick up the phone and scheduling the subs. They dont need to know about concrete, steel, hydraulics, pumps, etc etc.
    I think a more than a basic working knowledge of each item is necessary. After all, the profit margin for each pool starts at 5K to nearly 30K. It is not a 10 dollar widget they are selling.
    Quote Originally Posted by pabeader View Post
    Amen to this. My wife says, I can write a thesis on this subject. She is already bored to death with the technical details of why the stabilizer is required or what CYA means and the other thousand little things etc etc...lol
    mas985's Avatar
    Pleasanton, CA
    11,741
    It isn't just chemistry knowledge that they lack but few PBs really understand plumbing hydraulics especially when it comes to spas. So if you are building a spa, review the PBs design very carefully. Over the years, we have gotten many posts on problems with poor spa performance.
    Mark
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    TFP is my water maintenance expert and guide. I agree... in a perfect world, PB's would have a better understanding of water chemistry. But it seems we're in a time of specialists. For back pain, go to a spine doctor (and may even have to specify a lower spine guy).
    With my PB's assistant who helps new owners with maintenance, once he realized how much I've learned from TFP, we had more time for him to work with me on the pumps, etc. They really don't have all the time in the world.
    After 2 hours with my pb, I had no doubt how much he knows about each phase of pool building. He started out in plumbing which was a plus. And the icing on the cake for him is his integrity and he's a gentleman. (ex: he still refuses to take final payment until a couple of little things are done.) His downside? Communication. I think there are few PB's who have it all. I'm thrilled with the results and would have him build for me again.
    I live in the Cypress area. That $100k bid sounds way out of line - at least around here. I don't have your specs handy, so maybe you're going for a larger than average size pool and/or a lot of bells and whistles. But my pool didn't come close to that.
    Take care,
    Susan
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    Heck, my house in Alabama, was only a little more than that and it's 3000 sq fT!
    Mar 2013
    New Hampshire
    351
    I need to move to Alabama!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    It's for sale...
    philboyj's Avatar
    Jul 2015
    Houston TX
    326
    100k for house and add 100k for pool. Well balanced )
    Jan 2015
    Austin, TX
    1,095
    Plus the same people that no nothing about water chemistry are trying to sell you Nature2 or UV systems to help with maintenance. This is exactly why you shouldn't choose pool equipment based on PB recommendations.
    Pool is done! Only took 17 months! - Natural shape in-ground pool: 37x23, 505sq ft, 96ft perimeter, 7ft deep end, 18,950 gallons, tanning ledge, blue surf pebble sheen/luminous blue blend, Belgard coping, 910 sqft paver deck/walkways, retaining walls out the yinyang. Jandy SWG, 2 LED Color lights, VS 2HP Pump, 460sqft cartridge filter, PDA RS P8 controller. My build
    Sep 2015
    Mesa, AZ
    305
    I hope its a very large pool with a lot of upgrades for 100k.... In AZ 100k will buy you a resort pool
    Freeform /620 Surface/110 perimeter/20k gal/ Raised bond beam/Baja shelf (2)//Pentair- Intelliflo VS pump, Pentair Whisperflo 1hp// Easytouch, C&C 520 Cartridge, Intellichlor SWCG// A&A- Magnasweep in-floor, LeafVac, Venturi Skimmer,// Mini-pebble (Aqua Blue w abalone shell)//4 Pentair Globrite LEDs//3 sheer descents//Travertine coping and decking.
    Jul 2012
    Central Texas
    436
    My PB and I talked water chemistry a LOT after we were up and running and starting having problems with the pool maintenance services. He specifies and includes a Taylor kit as part of his package. About a year past our completed build, te came over one afternoon and we spent an hour going over the tests and the Taylor book. By that time, I was already lurking on TFP and was able to relate the two items. His expertise is in building pools and I've developed a level of expertise in maintaining mine. That's my responsibility as a pool owner that doesn't want to pay a service. He helped me get started and we've trade many emails back and forth. I tend however, to think that he is an exception (as well as being exceptional).
    Central TX / 12K GAL / IG / SWG / DE filter / Pentair SVRS & 3 swim jet pumps / Spa bench and jets / Single body of water / No heater.
    philboyj's Avatar
    Jul 2015
    Houston TX
    326
    Quote Originally Posted by ummgood View Post
    Great thought ummgood - I was laughing so loud just thinking about how much sense your comment made. Even though water chemistry knowledge was minimal, PB insisted on the Ozonator and UV thingie.
  20. Back To Top    #20
    philboyj's Avatar
    Jul 2015
    Houston TX
    326
    Quote Originally Posted by azjoshers79 View Post
    AZJOSHERS79 - I wish it were a resort pool. I dont mind PB's showing me designs where I said " I wish I had 100K plus to install this pool". Instead the thought has been more along the lines of "why would I pay even 50k for that pool. I will rather not have a pool than install that".
    On another 100K bid - which was on exactly one page, PB had so many typos ( it said freeform instead of geometric, it said Flagstone instead of travertine, no mention of any decking material, quoting older PCC2000 instead of newer PV3, no line item pricing - just one lumpsum number at 99,XXX - maybe that was a typo also - lol ) It made me wonder - what level of pools are these guys used to building that they give so scant attention to detail when they are trying to woo a client to build a pool that they think is worth 100K
    I will keep looking - I'm sure that the right PB will show up soon.
