Thread: shopping for chlorine
    Oct 2015
    Rancho Cordova CA
    9
    I was in Walmart and first went to the household bleach section. Great value brand seemed the cheapest but I notice some had the actual chlorine content and some of them didn't. Hard to tell what other additives they are putting in this stuff since its not listed. Obviously avoid scented etc but beyond that I'm concerned about what else they are putting in this stuff since it certainly isn't being marketed for pool use. I went over the to pool section and ended up buying a box, two gallons, of HTH brand liquid chlorine 10%.
    Greg ~ My pool: Plaster, 19,500 Gal Century V-Green 165 variable pump 1.65HP; Pentair Clean and ClearCtg filter; Polairs 380 with 1/2hp booster pump. Taylor K-2006
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: shopping for chlorine
    As long as the strength is listed as 8.25% it's the right stuff. Of course, no scents or splash less. Concentrated is fine. The 10% you found is fine too. I would worry about the age though. Look for date code on it. Same is true for regular bleach. But turnover with bleach is usually fast enough that it's fresh stuff.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    As long as it's not splash free/scented, the other 90%-91.75% is just water and a little bit of salt.
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,321
    check the dates...the walmart I went to during a SLAM last summer had VERY old bleach
    and when I opened the bottle I couldn't even smell it.
    Had to return 9 bottles and exchange for fresher chlorox...that wasn't fun.
    Dolphin E10 Cleaning Robot.
