Thread: Need the Best solar pool cover for Unheated pool
    Sep 2015
    La Porte, Texas
    37
    We are buying a house with a in ground Vinyl pool, No heater, and won't close for another 10 days.
    So I am looking for the Best (Yeah I Know) Solar pool cover, with the best
    (1) thermal efficiency e.g. heats the water up the most
    (2) durability/ longest lasting.
    Growing up we had a black plastic, Armalon (R) type cover and I swam year round.
    I would like to do that with this pool as well
    Who makes and sells what I need?
    17' x 35' x 8' in ground Vinyl lined, 24400 gal, age unknown
    Pentair Cartridge Filter
    Hayward Super II Pump
    ( liquid bleach)
    Richard
    Jun 2012
    western NY
    1,559
    Re: Need the Best solar pool cover for Unheated pool
    When I was younger(a long time ago) I was a life guard at a local motel pool. We had a solar cover that lasted forever. It was the same one for the 5 years I worked there, it was there when I started working there and was still in use after I left. I wish they were still made that way today. Forget trying to find the unicorn. Solar covers don't last all that long anymore. They also do not live up to their name as for heating. In cooler weather with full sun, you will gain some heat but, the primary job of a solar cover is to prevent heat loss due to evaporation. Once the air temp cools down to below the water temp the cover should be on. If the air temp is higher than the water temp it should be off.
    Forget durability. I had a high end ($$$$) cover once and it lasted maybe 3 years before it started to fall apart. I now have a cheap ($30) cover and it is at the end of it's 3rd season and I may be able to get next season out of it.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Sep 2015
    La Porte, Texas
    37
    Clear is supposed to pull in more radiant energy correct
    ( liquid bleach)
    Richard
    Jun 2012
    western NY
    1,559
    Some say the darker colors will transfer more heat to the water and some will claim the clear will allow more radiant energy to get to the pool. I have never seen much in the way of scientific evidence to back up one claim over another.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,075
    Quote Originally Posted by rick458 View Post
    This post
    and this thread describes the difference you can expect in the various solar covers. The main drawback with a clear cover is that while it does pull more heat in, it also allows UV rays to pass, thus chlorine breaks down quicker than with a darker cover.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    I have found the 8 mil size to be a reasonable cost and easy to handle on my own.
    I go with blue as that does heat the top foot of water while keeping the uv from breaking down
    the chlorine faster than a clear would.
    a good balance in my opinion of actual use.
    Dolphin E10 Cleaning Robot.
