Thread: Dolphin M5 Cable Repair or Replacement
    Nov 2013
    Phoenix, AZ
    15
    Just found out that my puppy, that loves the water, chewed through my cable.
    Is there anyway I can repair it?
    If not, do you have have a line an a replacement?
    Chris
    50,000 gallon, IG, pebble, Triton II sand filter, Hayward EchoStar VS pump, Dolphin M5
    Jun 2011
    Long Beach, CA
    2,778
    Re: Dolphin M5 Cable Repair or Replacement
    According to this place they are $159.99, Parts Diagram - Maytronics Dolphin Supreme M5 and Liberty | Marina Pool Spa & Patio. Since they sell it you should be able to replace it.
    Nov 2013
    Phoenix, AZ
    15
    Thanks ping!
    That's cheaper than I've found.
