Page 1 of 3 123 LastLast
Results 1 to 20 of 42
Thread: Pool company fired me. Time to learn to do on my own.
    Apr 2009
    Sarasota Florida
    143
    Well my pool company decided to stop service pools in my area so its time i learn to do it on my own. When i bought my house 7 years ago I attempted to take care of the pool which lasted about a 2 weeks when i turned cloudy to never come back. So i hired a company and as far as i new everything has been good. Their last service day is next week the 23rd so i figured i better learn before it is to late. The problem 7 years ago i came to find out was chlorine lock due to a high cya. Pool guy drained 1/3 of my pool and fixed the problem. Fast forward to today, armed with my new Taylor test kit i have gone and tested all my levels and to my dismay i find i once again may have a cya that is way to high. Pool is slightly cloudy. Below are my levels.
    Pool is an in ground plaster kidney shaped, ~15000 gallons.
    cya over 100, cant tell exactly as it looks like I can only test up to 100
    fc-12
    cc-0
    tc-12
    ph ~7.9
    ta-140
    ch-600
    From what I can tell it looks like the pool company wasn't doing as good as a job as i though and i may need to do a pool drain.
    Thanks in advance.
    Mike
    Kidney shaped ~ 10000 gallon Ig Plaster pool with pool cage. 120sf Cartridge filter. Pentair WhisperFlo WFDS-26, 230 Volt, 7.8/3.0 Amp, 1-1/2 Horsepower 2 speed pump, Solar panels on the roof. Heliotrope HelioMatic 4000D solar controller.
    Guest
    Re: Pool company fired me. Time to learn to do on my own.
    I assume you are using trichlor tabs in a feeder or floater? First advice is to read the Pool School section of the forum. The link is on the upper right corner of every page and also in my Sig. After reading through everything twice you should have a better basic understanding of what you need to do (including what info to include in your posts). Then you can post any questions you have and we are here to help!
    BTW, which Taylor kit did you get? If you have the K-2006 your are good to go. If you got the K-2005 then order the FAS-DPD chlorine test from TFTestkits or Taylor, your choice. If you have any other Taylor kit I would strongly suggest getting either a K-2006 or a TF100 from TFTestkits!
    Apr 2009
    Sarasota Florida
    143
    No floater, but i have a feeder. I will have to pop the cap and see if the pool company has been using it. I will post back in a bit.
    Feeder is empty, so I would assume that they are not using it. I appreciate your response and have reviewed the pool school for the last week. But as a new pool caretaker I am a bit apprehensive to do anything without a bit of reassurance. From what i can tell I need to get my cya lowered first. Seeing how changing 25% of the pool water is pretty drastic let alone expensive here in Florida, I am looking for input from the way more experienced members of this board then I. Hopefully i have now given enough to allow some direction.
    btw it is the Taylor k-2006 kit which is a very thorough kit and bought on the advise of the Pool School
    thanks
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Chances are if they are a 'once a week or so' kind of company, they were using it, and probably dichlor to weekly shock the pool...With a cartridge filter, it's easy for the CYA to get too high because you don't backwash frequently or have any kind of fresh water replacement. Where are you located? If you have no water table issues, I'd recommend draining about 1/3 again and try to bring it into the 70 range.
    Draining is a good idea....considering all of your numbers. Your PH is high, your TA is high and your CH is very high. But.... I would suggest you run a test of your refill/tap water too, and post those results. It could explain why those numbers are off too, and give you a heads up on what to expect when you refill. After you refill, let the water circulate a few hours before you retest.
    I'd also agree they were not doing a good job.
    11,969
    When is the last time they were there? The tablets could have dissolved....
    Edit: I'm wondering if they were using Cal-Hypo which would also explain the high calcium levels...
    No worries. I was a newbie 2 years ago and felt very overwhelmed by it all. You've got a good kit and all will be fine....we're here to help!
    :End Edit
    Apr 2009
    Sarasota Florida
    143
    Quote Originally Posted by frustratedpoolmom
    Exactally, it was a once a week pool company. I am located in Southwest Florida on the gulf coast.
    Apr 2009
    Sarasota Florida
    143
    Thursday
    11,969
    I'm posting as you post! See my edit above....
    Apr 2009
    Sarasota Florida
    143
    Yup saw it, will test tap water and post those results later today. Time to get a submersible pump i guess
    Guest
    Don't be surprised if you need to do a series of drains and refills. As we are coming into rainy season here in Florida (for all you non Floridians, we have two seasons here--wet and dry! In winter we are actually considered to be high desert!) I would recommend not draining more than perhaps a foot below your skimmer each time you drain. It will take a bit longer to get your CYA down but this way you don't have to worry about hydrostatic pressure.
    Anyway, there is no reason to be apprehensive! If everyone else on here can do it so can you! Anyway, that's why the more experienced members and the pool professionals that are active contributors are here. We have all been certified in "Hand-Holding Nervous New Members"!
    Apr 2009
    Sarasota Florida
    143
    tap water
    PH - 7
    TA - 40
    CH - 200
    Didn't test for CYa, FC or CC as i suspect they will not be present.
    Mike
    Mar 2009
    Woods of North Florida
    148
    I don't have any experience with pool services, but shouldn't they be responsible for any cost to get the pool like it should be? You are still paying them (until at least the 23rd). Maybe they could re-imburse you for the cost of the water to refill? Do you have a contract that states what they were responsible for? Either way, the people of this board have been very nice to me. I am a newbie at all this and they have been great. You are in good hands!
    24' Seaspray Evolution CLX Above Ground Pool (~13600 gallons)
    Pentair Sand Dollar SD60 / 22.5" filter / Maximum Flow Rate 60 GPM
    Pentair Dynamo Pump 1 1/2 HP
    Apr 2009
    Sarasota Florida
    143
    Quote Originally Posted by numberonenole
    You bring up some great points. Even though most pool companies do not use written contracts there is still an inferred contract for services that I am paying for. I am going to have a 3rd party test the levels tomorrow since i am new at this. If their findings confirm mine I will be sending a nicely worded email to my service provider stating that I expect my pool to be handed over to me with the chemical levels within industry standard ranges. And that any costs associated with bringing the levels in check will be paid by them. I will let you know how it goes.
    11,969
    Quote Originally Posted by mdhwoods
    The only problem with "industry standard ranges" is the industry will tell you that CYA of 100-150 is okay....
    Good luck!
    Guest
    I would not hold my breath since you ARE within range for a residential pool and that is probably what they will tell you. IF you were a licensed commercial pool it would be a different story. Good luck.
    Butterfly's Avatar
    South Carolina
    10,045
    tap water
    PH - 7
    TA - 40
    CH - 200
    Mike
    Hi Mike,
    You are correct to not test for CYA. None should be there! However, when I tested our tap water in 2006, it had FC and CC
    Welcome to the forum!
    You're done SLAMing when:
    Jan 2009
    Cupertino, CA
    1,966
    Check with the local water company about rules for draining a pool. Where I am, I can backwash onto the ground but draining has to go into the sewer (not the storm drain on the street). They don't want all those nasty pool chemicals getting into the ground water.
    --paulr
    BBB "Intermediate Swimmer"
    Apr 2009
    Sarasota Florida
    143
    Ok so you guys make some good points on Industry standards of cya levels and since at the time of posting all i knew is that mine was at least 100, so I retested like this. If this is an inaccurate way of determining high cya levels please correct me.
    I took the exact same proportions of pool water and distilled water and mixed them together thoroughly. I then retested strickly following the cya testing directions and came up with 100. Seeing how I diluted the pool water by 50% I then doubled the 100 to get 200. If i did this correct my cya is 200.
    If it is 200 does that give me some leeway with my pool company? Is a cya of 200 ever really an acceptable level?
    Thanks
    11,969
    Thanks
    It should. No, not in any alternate reality....
  20. Back To Top    #20
    30,432
    Regardless of blame, be sure you keep plenty of chlorine in that pool (like 12-14ppm) or go ahead and begin the drain refill process to get your CYA around 40-50 or so.
    YOur pool is a prime candidate for an algae bloom.
