Results 1 to 14 of 14
Thread: Lost water and no power
    Hey all, so this AM hot tub was fine.. left and came home after about 4 hours and noticed 2/3 of the water gone and no power. What is perplexing is the water loss. Makes no sense to me. Tub is on an elevated deck and there is no sign for water loss underneath it. Even took of the panels and completely dry. Ideas?
    2003 Marquis Euphoria - 400gal
    Jan 2012
    'burbs of Augusta, Georgia
    7,239
    Re: Lost water and no power
    Whoa! That is odd! Anyone playing tricks on you???
    Where does your water go when you drain the tub? How do you normally remove water?
    Weird right... I normally use a small submersible pump to drain it.
    Jun 2015
    Wildomar, California
    423
    Gnomes, it's gnomes.
    wjr75's Avatar
    Jun 2013
    IL
    836
    Did you have a garden hose left in it that could have started a siphon?
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Quote Originally Posted by wjr75 View Post
    I did as I topped it off this AM! Didn't even think of that!!! LOL
    So you think it siphoned so low something tripped on the board?
    wjr75's Avatar
    Jun 2013
    IL
    836
    Once there was no flow it probably tripped the flow sensor. I left the hose once in my parents above ground. The hose had some leaks which caused it to siphon a bunch of water over a couple of days before I noticed.
    Ok.. I would think I would still at least have power to the panel even with the sensor tripped right?
    wjr75's Avatar
    Jun 2013
    IL
    836
    Ya, if you loss all power maybe something else is happening. Did you check the breaker at the house?
    Yeah.. breaker is good. Going to try to replace the two larger fusetron fuses.. the smaller clear ones look fine. If that does not work will have to place a service call
    fuses tested good with multimeter.. at a loss.. waiting on service guy to show. Will keep you all updated.
    Ended up being the heating element which got toasted with the loss of water.. $220 replaced.. not bad.. just irritating it was self inflicted
    Jan 2012
    7,239
    On the plus side- you'll *never* make that mistake again
    Indeed!!!!
