Results 1 to 14 of 14
Thread: Winterizing my new Raypak Heater
    Jul 2012
    Chicago, IL
    358
    First, I can't believe how much more enjoyment my wife and young daughters got out of our pool this season once we added the above mentioned heater. It is a game changer!
    Anyway, now that it is getting time to close, what are thoughts on the heater? Given the cost of the thing, my first inclination is not to leave it out to get battered by a Chicago winter. Of course, given the size, bringing it in risks banging it around, and I am guessing they are made to stay out anyway??
    What are thoughts? Leave outside and stop worrying? And is the only winterizing of the heater that needs to be done is turn off the gas and open the drain plug? It seems too simple.
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Winterizing my new Raypak Heater
    Instructions may only say to remove the drain plug. In my opinion, you need to blow compressed air through the heater with the drain plugs removed until you see no misting come out of the drains. Then pause the air flow and do it again. And maybe again. You want to get as much water out of the heater element as possible. Only use about 20-30 psi if you're using a compressor.
    Isolated Spa - 345 Gallons
    Jun 2015
    Wildomar, California
    423
    Blow air thru the exchanger to remove all possible water. Remove the plugs from BOTH headers. And, remove the pressure switch tubing from the manifold! Oh, turn the gas off.
    wjr75's Avatar
    Jun 2013
    IL
    836
    We keep our heater outside uncovered for the winter. We actually use it for the hot tub until December. Not sure if they sell covers or not but it may actually keep moisture in it which may accelerated corrosion.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Jun 2012
    western NY
    1,562
    My heater stays out year round (10 years now). Snow is really no different than rain and my western NY winters are just as rough as anything Chicago gets. I make sure the water is drained out and turn off the gas although there is no real reason to have to do that if the plumbing is good. In fact I am sure there has been a season or two where I forgot to. If you are real concerned, buy a gas grill cover that will fit over it and use that to cover it
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jul 2012
    Chicago, IL
    358
    Great, thanks for the thoughts everyone!
    Jul 2012
    Chicago, IL
    358
    Quick follow up on winterizing the heater, I've drained and blown compressed air through the system, is it best to leave the drain plug out and leave the intake and return heads (if those are the correct terms?) open? Or does that risk rain and snow re-entering the system?
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Mine came with plugs for the intake and returns (you could devise your own). My manual says do not put a cover over the heature will trap moisture. It also says to remove the presure switch. I keep the switch inside the house.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Jul 2012
    Chicago, IL
    358
    I am definitely not going to cover, not sure I have a pressure switch?? Didn't see anything in the manual. Do you leave the drain plug removed or replace after draining?
    banditig's Avatar
    Sep 2015
    Ohio
    466
    I leave the drain plug out. Mine has pressure switch right behind a small panel near drain plug
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Raypak Residential Pool /Spa Heaters - Pool/Spa Heaters, 206A-406A
    they should have your model with winter instructions
    Jul 2012
    Chicago, IL
    358
    Thanks Banditig. I do have the manual, but the winterizing instructions were so thin it seems like there had to be more. All the manual says is turn off the gas and electrical supply and open the drain plug, which I have done.
    Also, blow out any debris from underneath the heater that might hold or catch water. We cover our filter, pump, lines, and heater with one large tarp but there is lots of air circulating. All lines are filled with anti-freeze.
    Gary R.
    Quote Originally Posted by Pauls234 View Post
    18 X 32 Oval Inground Gunite Pool 20,000 Gallons Epoxy Painted in 2012
    Tagelus Sand Filter TA 60 D/TA 60-Hayward Super Pumps 1 H.P.
    Ray-Pac Heater 266,000 BTU, KLeen Machine Pool Cleaner
    Solar Cover-Rocky's Pool Cover Reel-Intermatic T104R Timer
    TF-100 Test Kit-PoolSkim Skimmer
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Your probably ok. Some heaters let you reverse the flow by rotating the header 180 degrees. I think that's why mine has switch on the bottom
