Results 1 to 12 of 12
Thread: Should I wait to plaster (Pebble Sheen) until next year?
    flan_2009's Avatar
    Jun 2015
    Austin
    15
    Hi- We are at the ending phase of the pool build. Gunite was poured 3 weeks ago, coping and tiling are also completed. My question is should I wait to plaster until next year? We know we will not use the pool this year. I am also concerned about having to brush it constantly the first month and I don't think it can be done properly if not in the pool. Any cons with waiting? Will I have to water the gunite daily throughout fall and winter? I appreciate any advice on which direction to go. Thanks!
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Re: Should I wait to plaster (Pebble Sheen) until next year?
    I don't have answers but those are great questions! I also wonder about brushing mine when (when we get to that stage) during cold months...
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    JoyfulNoise's Avatar
    May 2015
    13,250
    Your gunite shell should be ok but it depends on how wet your winters are and how high the water table is. An unfilled pool is like a boat, if the water table rises enough and if there is no hydrostatic relief, the shell can potential lift out of the ground. If you have a really wet winter, your gunite shell will fill up with a lot of water.
    What does your PB want to do? Do you know how high your water table is?
    Matt
    Jan 2015
    Austin, TX
    1,095
    I know my pool has been empty for forever in Austin. My PB took a plug out of the main drain so it can let water into the shell so it won't pop out of the ground. What that means is I have about a foot of really nasty water at the bottom of my pool shell.
    Pool is done! Only took 17 months! - Natural shape in-ground pool: 37x23, 505sq ft, 96ft perimeter, 7ft deep end, 18,950 gallons, tanning ledge, blue surf pebble sheen/luminous blue blend, Belgard coping, 910 sqft paver deck/walkways, retaining walls out the yinyang. Jandy SWG, 2 LED Color lights, VS 2HP Pump, 460sqft cartridge filter, PDA RS P8 controller. My build
    flan_2009's Avatar
    Jun 2015
    Austin
    15
    @Joyful - I do not know what the water table is but I can ask the PB. I sent the PB an email this morning asking if waiting was a possibility.
    @Ummgood- the nasty water is concern but I think I can deal with that. Looking at your pool post you would prefer the plaster be done as soon as possible.
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    Quote Originally Posted by ummgood View Post
    In ours, the gunite company left 4 or 5 softball size holes in the shell. We, too, have about 8 inches or so of nasty water in the bottom. Well, after the recent storm it's all the way into the shallow end.
    Build thread
    IG Gunite w/ spa, PebbleSheen Blue Surf, 18K gallons 500sqft
    Jandy: 60 DE filter, 2.0 VS (main pump), 2.0 Flo Pro (features)
    Paramount PV3 w/ 1.5 Stealth, PDA PS6, JXi 400K NG
    Flagstone coping & wall. Stamped Concrete from BrickForm. TF-100 w/Speed Stir.
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    We are in the same boat and scheduled plaster for next spring. Like bdrum, our pool has holes for groundwater, but no nasty water -- water table is quite low.
    My Pool Build (2015): inground 12K gals gunite/plaster pool, SWG, 2-speed pump, cartridge filter, gas heater, and Dolphon s300i. TF-100 Test Kit w/ Speed Stir
    Jan 2015
    Austin, TX
    1,095
    Quote Originally Posted by flan_2009 View Post
    Actually I wanted it done as soon as possible but now I asked them to wait a couple weeks because they waited so long now it is overlapping with my business trips and surgery and I would prefer to be able to watch the pool get plastered in person.
    Dec 2014
    Cypress, Texas
    200
    Quote Originally Posted by Nursenini View Post
    Hmmm, so are we saying we need to be in the pool for brushing?
    For some reason I was thinking I could use a pole and do it from outside. I hope that's the case since the pool will probably be done in February sometime
    Maybe I need a wetsuit ��
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Typically you can reach the entire surface of your plaster with a pole mounted brush.
    The advantages of of doing it asap are:
    - The chemistry will be more stable with the curing of the plaster.
    - While you are getting used to treating your pool water over winter, everything happens slower than in summer.
    - No surprises waiting for busy plaster companies, eating into swim season.
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,624
    You can brush from outside the pool. I DO find it is easier to brush from inside but during the cold times can and do brush from outside.....burrrrrr
    Kim
    Aug 2014
    Houston tx
    2,525
    That's good to know!
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
