Thread: Just finished SLAM, water is cloudy
    Oct 2015
    THE WOODLANDS, tx
    65
    Hi All,
    So I finished the SLAM on 10/24. Pool has looked great through the rain on the weekend. When the filter pump turned on his morning, I saw a brown cloud coming out of the jets for a few seconds and the pool changed colors before my eyes. The water is cloudy now
    These are my FC and CC levels in the past three days:
    Date Time Sample Drops FC CC
    10/24/2015 720 10 ml 62 31 0
    10/25/2015 826 10 ml 42 21 0
    10/26/2015 1044 10 ml 33 16.5 0
    10/27/2015 834 10ml 31 15.5 0.5
    Should I hope for the brown stuff to be left over dirt from the rock wash (last week) and rain and wait for it to settle down? Or should I start another SLAM?
    Many thanks!
    ~20,000 gallons, IG white plaster, Cartridge filter (make unknown), Filter Pump (Jandy Stealth Model # SHPM2.0), Probably over 10 years old, Spa, non-functional SWG (bad sensor), Taylor K-2600
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: Just finished SLAM, water is cloudy
    Give it a day of running the filter. If it doesn't clear up then you might need to SLaM
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Oct 2015
    THE WOODLANDS, tx
    65
    ok thanks
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,013
    There is no need to slam unless you fail the overnight chlorine loss test, or you have excessive CC's.
    Often time, leaves and other things that get blown into the pool will cause CC's. Anything that is organic can do it. If ever a doubt, if you need to slam, do the OCLT to confirm it after all leaves etc have been cleaned out.
    Divin Dave,
    Oct 2015
    THE WOODLANDS, tx
    65
    I ran the filter pump overnight and water is clear again! Also passed OCLT so all is good.
    Right not, FC is at 12.5. Should I start testing for the rest of the chemicals once FC goes under 10?
    Thanks!
    Sep 2013
    Charleston, SC
    540
    Congratulations! Yes you can do a complete battery of tests once you get your FC below 10. They probably are where they were before you started the SLAM, but I always feel better doing a complete battery.
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
