Thread: Robot timers
    Mar 2014
    Angleton, Tx
    91
    Robot timers
    The ones that have timers on your robots, how often do yall actually use them? its tough to decide with all the options. Do yall leave them in on a set schedule or toss them in when needed?
    Any good online sources? Or local in or around the Houston area to purchase from?
    IG Pebble sheen blue surf approx. 14k gallon, beach entry, 7' spa, 3.5 ton jumping rock/waterfall, Pentair 2hp whisper flo, booster pump, 520 cartridge filter, Stenner Econ T, 400k master temp heater, easy touch controls,TF-100 w/speedstir
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Robot timers
    I use mine all the time, like last night. I put it on delay after brushing the pool. That gives time for stuff to settle and be picked up when he comes on later.
    I would buy from a local supplier in Your area so they can do warranty work or whatever should you need it. Go with all the robot you can possibly afford and you'll get the most out of owning one. Your pool certainly warrants that.
    Essential Links:
    Mar 2014
    Angleton, Tx
    91
    Re: Robot timers
    Thanks, good points
    Mar 2015
    South Texas
    411
    Re: Robot timers
    Quote Originally Posted by Patrick_B View Post
    I thought most robots brush AND vaccuum?!?! Excuse the newb question
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
    Mar 2014
    Angleton, Tx
    91
    Re: Robot timers
    Quote Originally Posted by nlindelldc View Post
    from what i understand they do a great job of both, but you may have to brush areas the robot cannot get to.
