Thread: Manual Vacuum Setup question.
    Oct 2015
    Pentas/TX
    28
    So our new pool is full with dirt, grass and small debris. I didn't want to invest in an automatic cleaner just yet, even though I did leave an inlet to connect one, so I ordered a Hayward 1HP pump, Pentair vac pro (19"), and a 50' hose along with an inline canister. My question is, should I get a small cartridge filter? say a 50sq ft size just for when I vacuum the pool? The main reason I went ahead and did this was because there are possibly two other pools on the way that I will help build for my brothers. We agreed to share the expense and lend each other the equipment. As promising and great the automatic cleaners look we simply wanted to wait on purchasing one. Anyway should I get a small cartridge filter like the Hayward C500 Star Clear Cartridge 50sq ft.?
    http://www.poolsupplyworld.com/Haywa...ilter/C500.htm
    I have already ordered the
    Hayward SP1580 1HP Power-Flo LX Series with Cord.
    Pentair R201296 229 Pro Vac
    Haviland PA00061-HS50 50ft hose (1.5")
    Hayward W560 Canister
    Thanks!
    40x20 Rectangular (3'to6' depth),Cantilevered Deck, Whisperflo 2HP FullRated, DE 60 SQft Filter, 2 Intellibrite 12V 5G Color Lights, Intellibrite Controller
    Oct 2015
    watuaga
    8
    Re: Manual Vacuum Setup question.
    Sounds like the extra pump is overkill unless this pool is just hammered. If your scared to put it into your d.e. filter that 50 sq cartridge will be a nightmare of cleaning for no reason, just dump the pool water to the street or yard in that case. For routine vacuming the leaf canister you have is just what you need to vacuum with your filter pump. If you cannot block off a skimmer with valves i use a pop bottle full of water to stick in one skimmer and divert suction to the other. The rig you bought would make alot of pool services green with envy. So send the pump back, and make a commitment to never let your pool get that green and always use your leaf canister ALWAYS!
    Oct 2015
    Pentas/TX
    28
    Thanks for the reply.
