Thread: add liquid chlorine / bleach
    Oct 2015
    Orinda, California
    56
    Hi Forum - basic question for all. Where should I add liquid chlorine %8.25? Empty 121 oz through skimmer, deep end, or shallow? Thanks in advance
    28,000 gallon IG pool, plaster, built approx. 1970.
    1 1/2 " plumbing. Pentair, Intelliflo 3 hp variable speed.
    Crystal Water cartridge filter system, model #425
    Dolphin Deluxe 4,
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    Re: add liquid chlorine / bleach
    Pour slowly in front of a return near the deep end. Slowly as in it would take a couple of minutes to empty the bottle. Let the pump run for at least 30 minutes to ensure good mixing.
    Build thread
    IG Gunite w/ spa, PebbleSheen Blue Surf, 18K gallons 500sqft
    Jandy: 60 DE filter, 2.0 VS (main pump), 2.0 Flo Pro (features)
    Paramount PV3 w/ 1.5 Stealth, PDA PS6, JXi 400K NG
    Flagstone coping & wall. Stamped Concrete from BrickForm. TF-100 w/Speed Stir.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    You can see a kind of haze as you introduce the bleach/chlorine in, if you do it slowly/correctly the jet from the return will quickly dissipate that.
    Just make sure you don't go too fast...I did that a few months back and could see the haze of the chemical near the bottom of the deep end, then
    I had to adjust the jet down to clear it up sitting there.
    My deep end jet has to point level and slightly over to my skimmer or the leaves never get skimmed.
    Dolphin E10 Cleaning Robot.
    Aug 2014
    Northern IL
    4,615
    Agree on the deep end/return part. I almost always brush at least the deep end if I am adding more than a little chlorine. Also, your pool is good-sized. I would keep the pump on for at least an hour for mixing.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Here is a handy link on how to add chemicals, what they are and what they do.
