Thread: Shallow end next to spa vs tanning ledge?
    Dec 2014
    Cypress, Texas
    200
    We're looking at a 8x32 rectangle with a 6x8 spa at one end and a tanning ledge on the other.
    We're wanting depth going from 4-5 feet.
    I have 2 different drawings from two different pool companies and both show the shallow end next to the spa, even though it's on opposite sides of the pool on the two drawings.
    I was thinking the shallow end should be next to the tanning ledge. Is there a reason to put it next to the spa instead?
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    Re: Shallow end next to spa vs tanning ledge?
    Quote Originally Posted by Mamiamjo View Post
    We were told that the spa next to the shallow end would facilitate socializing. The folks in the spa could talk to the folks standing around in the shallow end.
    We opted to have the spa near the deep end to maximize shallow end area.
    Build thread
    IG Gunite w/ spa, PebbleSheen Blue Surf, 18K gallons 500sqft
    Jandy: 60 DE filter, 2.0 VS (main pump), 2.0 Flo Pro (features)
    Paramount PV3 w/ 1.5 Stealth, PDA PS6, JXi 400K NG
    Flagstone coping & wall. Stamped Concrete from BrickForm. TF-100 w/Speed Stir.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,802
    All adults except those on the lowest percentile will be able to stand next the the spa at either end. I can picture being able to stand in the pool with my armpits resting on the spillover, whichever end that would work on.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    We put both the spa and the sun shelf on the shallow end. The pool and the spa/sun shelf are two rectangles merged at the corners.
    chiefwej
    Dec 2014
    Cypress, Texas
    200
    Thanks everyone. So what I'm gathering is that there is no set rule that the spa should be at the shallow end.
    I think I'd rather have the tanning ledge at the shallow (4ft) end and the spa at the deeper end (5ft)
    I will ask the PB and see what he says
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    My two closest neighbors, one has the spa at the shallow end and one at the deep. Whatever you want is the right answer.
    chiefwej
