Thread: Heat Pump Not Winterized
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    Is there any special problem with pool heat pumps not being winterized? I know if I keep the water moving in freezing temperatures, that the pump and filter will be ok but now wondering if the piping inside a heat pump is more vulnerable to freezing temps than the 2 inch PVC would be. Thanks!
    True L 45,000 gal Hayward IG vinyl pool. Hayward Tristar 2.40 THP; 1.5 FRHP/1.60 SF. Hayward Model # S310T2 Sand Filter. Aqua Rite T-15. Aqua Comfort 154,000 BTU Heat Pump. TF-100
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Heat Pump Not Winterized
    Two reasons it would be more vulnerable.
    1. Smaller diameter, less volume = less energy loss (in heat) required to freeze the water.
    2. I'm not sure what material the piping is made of but it may be more conductive that PVC, allowing heat to escape faster.
    Isolated Spa - 345 Gallons
