Page 1 of 2 12 LastLast
Results 1 to 20 of 38
Thread: Just refilled and testing, need advice please
    Oct 2015
    Tampa, FL
    28
    So after having motor and impeller issues and getting those resolved and then being out of town 2 weeks, I needed to start over with the water and chemicals as the water had turned green and CYA was at least 200.
    I drained about 85% of the water out and refilled it with city water (can't wait for the next water bill). I used the TF-100 test kit to test with. CYA is still a bit high but I can't afford to drain and fill yet again. While I was draining I was using the vacuum sweeper to suck up as much algae off the bottom as I could.
    FC = 1.5
    CC = 0.5
    TC = 2.0
    TA = 230
    CYA = 100
    Cl = 0.5
    ph = 7.8
    Suggestions?
    Mark
    12' x 4' above ground installed in-ground, Hayward Super II pump with replacement Hayward SPX1607Z1M 1hp motor, Hayward C-800 filter
    Pool - Unclenard
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Just refilled and testing, need advice please
    You need to get your FC up to at least 12 and possibly higher.
    You also need to get your pH down. I would recommend using MA to lower it.
    Lower the pH first, because once you raise your FC up over 10 the pH test gets wonky.
    Redo the CYA test using 50% pool water and 50% tap water. Since the test is only good to 100 you still need to dilute to get a better idea what it really is.
    Is your water still green? If so you are going to need to SLAM it. With a CYA > 100 it's going to take a lot of bleach, but it can be done.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Oct 2015
    Tampa, FL
    28
    The pool has a very slight green tint to it. It was greener when I first bought the house and was able to clear it up spending a bunch of money at Pinch a Penny. So I'm confident it can be cleared up again without draining. Should I put any bleach in it while I get the ph down?
    Mark
    Pool - Unclenard
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    You can, but be careful about mixing them. You should allow at least 30 mins of good circulation between adding the MA and adding the bleach.
    Please read this page for good info about chems and their use: Recommended Pool Chemicals
    Oct 2015
    Tampa, FL
    28
    Thanks for the quick replies. I added the MA, how long should I wait to test ph again? According to the PoolMath my normal target is 4 for FC but for shock is 39. So I should put 39 in the target right? If so, it is saying 189 oz of 8.25% bleach. Is there anything else to SLAM the pool? I couldn't find any sticky threads on SLAMing. Or should I follow this? Turning Your Green Swamp Back into a Sparkling Oasis
    Mark
    Pool - Unclenard
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Here you go: Pool School - How To
    Use this chart: Pool School - Chlorine / CYA Chart
    Most chems it's 30 mins of good circulation before retest.
    Aug 2014
    Shallotte, NC
    693
    Minimum of 30 minutes after adding MA should be enough time to mix. You need to get your pH right before going over 10 ppm of chlorine.... or the color test will bleach out, giving inaccurate results.
    See here:
    http://www.troublefreepool.com/conte...tain-shockingl
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    Quote Originally Posted by pabeader View Post
    This! Anytime I see a 100 CYA measurement I'm immediately suspect that's it's at least 100 and subject to a testing limitation. Find out the true CYA level first. At least you'll know exactly what you're up against. Sorry.
    11K gal IG screened-in plaster pool w/ spa
    pentair 150 cartridge filter, Pentair Intelliflow VS pump,
    Aquarite AQR15 SWG, AquaCal Heatwave Heat Pump, TF-100 test kit
    Oct 2015
    Tampa, FL
    28
    I tested CYA with 50% pool water and 50% tap water and it read 50, so I guess it really was 100 with just the pool water. I added the 189 oz of bleach 3 hours ago and just rechecked the level. The FC was at 26 so I added another 65 oz to get the level closer to target of 39. I'll test again in a couple more hours. With all the bleach in the pool to shock it I'm assuming there is no point in doing the ph test since it will be off. Since it was good before I started to shock it I don't need to worry about it until after the SLAM is complete?
    Thanks for help!
    Mark
    Pool - Unclenard
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    For a SLAM, good pH is 7.2. I think you were at 7.8 last you reported. Did you test before you started the chlorine additions?
    Once you get the FC up to SLAM level you need to test after about 1 hour or so and add back whatever you need to get it back up. This is called the M or Maintain part of the SLaM
    Just keep doing that until you get a small drop between tests. Then you can start to stretch the cycle out to every couple of hours. Keep that up until the water is crystal clear.
    Oct 2015
    Tampa, FL
    28
    ph was 7.5. Ok, I'll check it more frequently then. Thanks!
    Mark
    Pool - Unclenard
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    You were correct about the pH retest. Once FC is over 10 the test becomes wonky.
    Also, you'll want to take pictures each day. Maybe a couple times a day at the beginning. Would love for you to post them so we can all enjoy the progress
    I would look for a feature that goes into the water, like steps or a ladder or even the vacuum hose. As the water starts to clear you'll get to see more and more of the item.
    Oct 2015
    Tampa, FL
    28
    Here is the current state of my little pool. Not too green to start with but can't see the cleaner at the bottom too well. And no there isn't a tablet in the chlorine floater, I just haven't taken it out of the pool. And the hose isn't on just haven't pulled it out since refilling it.
    By the way the tip on the forum about getting a fire hose off eBay for draining was great! Although I bought a 1.5" and should have gotten a 2" hose, but I used an adapter to make it work. Those blue hoses have always busted when I've used them.
    Mark
    Pool - Unclenard
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    You're right. Not too bad! Interesting install.
    Shouldn't take too long, but we've been fooled before.
    Oct 2015
    Tampa, FL
    28
    Yes it is an interesting little pool. When I was with the realtor looking at houses I laughed the first time I saw the pool. I wasn't really looking for a house with a pool but figured it would be nice to have to relax in sometimes since I don't really swim laps or have kids at home any more. It has been the butt of many jokes. I'm working on getting rid of the bamboo near the pool and then will be having landscaping done which will include some pavers in the backyard. I was thinking about doing stone around sides the pool and on the top edge where the tile is now.
    Mark
    Pool - Unclenard
    Oct 2015
    Tampa, FL
    28
    Well it has held the FC level for 3 hours now. I'll check it again in a couple hours and then first thing in the morning.
    Mark
    Pool - Unclenard
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    You have the pump running continuously, right?
    Oct 2015
    Tampa, FL
    28
    Yes I planned on keep the pump on all night as well.
    Mark
    Pool - Unclenard
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Good to hear. Can't wait to see how this one turns out.
  20. Back To Top    #20
    Oct 2015
    Tampa, FL
    28
    So over night the FC dropped from 43 to 38 but it had been raining over night too. I don't think the pool really looks green, I think it is just cloudy? Here is a picture from this morning to compare to the previous one I posted yesterday.
    Should I bring the level back up again or do other tests besides FC at this point?
    Mark
    Pool - Unclenard
