Thread: Stain Problem
    Stain Problem
    Hi All,
    I have a plaster pool and have several stains primarily in the deep end and closer to edge of pool. The stains are about 1 to 2 inches in diameter and they are yellow green colour. They are also rough when you touch them and they feel like they are attached to the pool surface. I have tried scraping off but they are too hard.
    I have a few trees close to pool and leaves always fall in.
    My water is usually well balanced. I use a Taylors K2006 kit to test water and my numbers are CH=3.5 , PH=7.3 , TA=70, CA=600, CYA=20. I have an automated chlorinated and PH generally is around 7.4.
    Any ideas on how to remove these stains.
    Regards
    George
    Pool size (50,000 lt /13000 gal), Concrete Plaster 2 years old
    Automatic SWG (Zodiac Pro) for chlorine and acid, Solar heated
    Taylor K-2006 test kit
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Re: Stain Problem
    To help you determine if the stain is organic or metal: take some vitamin C tablets and hold it against the stain. If it lightens it, it most likely is metal. Take a chlorine puck (avail individually at many pool stores) and hold it against the stain. If it lightens it it most likely is organic.
    Treatment for metal stains can mean as much as an AA treatment and/or metal sequestrants. Organic stains require chlorine.
    Pool School - Metals in the Water and Metal Stains
