I had the pool replastered 5 days ago. At the time, I tested the tap water and found it to be TA of 290 and CH of 330. After I filled the pool, 8 hours after the plastering was done, here is what the pool water tests at:
FC = 0.2
CC = 1.4
pH = 8+
drops to 7.4 = 4
TA = 150
CH = 150
CYA = 0
There has been no plaster dust in the pool, and the pool is crystal clear. I have been brushing/vacuuming. I have only added 2 quarts of The Blue Stuff and nothing else. What do you recommend I add at this time? Should I start my Stenner chlorine pump? Should I put in any chemicals before I do that? Thank you.
FC = 0.2
CC = 1.4
pH = 8+
drops to 7.4 = 4
TA = 150
CH = 150
CYA = 0
