Thread: Is this right?
    Oct 2015
    San Diego, Ca.
    650
    Is this right?
    I'm leaving for a week soon.
    My CYA is 60.
    My FC is 7
    My CC is 0
    I use about 2 FC per day.
    Can I add 3.5 gallons of Chlorine just before I leave and expect good a FC level a week later?
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
    Re: Is this right?
    The loss rate is proportional to the fc/cya ratio. With a higher ratio, your loss rate will be higher. So, it's not as easy as just adding enough for a two ppm loss per day. That said, at this time of year, you'll probably be fine with your plan.
    Support the site
