Thread: Closing, Blowing, and Creation.
    rgrecco's Avatar
    Aug 2015
    Fredericksburg, VA
    8
    I watched my pool company close up my pool for the forest time this year (first closing was included with purchase)...
    Unfortunatly i didn't know any better when they installed the pool and they plumbed the main drain to the skimmer...
    The way they took care of it was they fed some backwash hose into the line attached it to a blower and blew it out and quickly pulled and capped it...
    Then they attached the same blower with back wash hose to my backwash port on the pump, opened the valve and blew out the skimmer and returns from there...
    Now i don't plan on using a company next year and plan on taking care of our myself... i thought about how to create a similar contraption to connect to my compressor.
    Will this is what i came up with:
    Do you think it will work?
    Do you think the compressor will be able to blow out the main drain line?
    Any advice and input would be great... I have till next fall to figure it out...
    RON GRECCO
    Steel Frame Vinyl Liner ~14,000 gal. IGP [14'x28' (3' shallow - 6' deep) w/ 8' Side Entry Steps]
    1hp Hayward SuperPumps
    Hayward Pro-Series Top Mount Sand filter
    Hayward T-9 Salt Cell
    Apr 2015
    South Central PA
    297
    Re: Closing, Blowing, and Creation.
    I have a main drain plumbed through the skimmer as well. The hole is threaded, so I bought a PVC threaded bushing (2" pipe), followed by a 2" to 1.5" reducer bushing, short length of 1.5" pipe, and a ball valve that ends up in the weir door area. I put an o-ring on the threaded bushing and some silicone grease on the threads, and tightened it in the main drain hole. I used a shop vac to blow the water several feet deep and closed the valve. It works well to create an air lock. I would think the compressor would work good. You could put a PVC cap with a valve stem in it on the assembly I made and you would have a nice air lock set up.
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    rgrecco's Avatar
    Aug 2015
    Fredericksburg, VA
    8
    Thanks for the reply Dodge
    I'm going to have to take a look... i don't believe my main drain hole is threaded...
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    A blower is a high volume, low pressure device and is inherently safe to use blowing out pool water lines. A compressor is a low volume, high pressure device and can damage your piping if not set correctly. Your compressor has the potential of showing you where your weakest piping glue joint is. Unfortunately that could be several feet down, under concrete. I think your better off using a blower.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,256
    Unfortunately I didn't know any better when they installed the pool and they plumbed the main drain to the skimmer... The way they took care of it was they fed some backwash hose into the line attached it to a blower and blew it out and quickly pulled and capped it... Then they attached the same blower with back wash hose to my backwash port on the pump, opened the valve and blew out the skimmer and returns from there...
    These days, it would have been better to plumb the MD separately, but at this point it is too late. If your MD is not threaded, then you will have to create something similar as the blue hose will expand and this will work. Regarding your MD, if threaded, then you can easily create an adapter add possibly add a plastic shut off valve. The multi-port will be on recirculate and blow everything out through the skimmer.
    Please upload pictures of the skimmer basket and equipment pad, as this would be helpful. It would be best to rotate, save and upload (if necessary). As gtemkin mentions, your compressor may show you where the weakest piping glue joint is, possibly causing problems. I would recommend a Cyclone as it is specially designed for swimming pools (High Volume and low pressure). One small adapter at skimmer and you can clear everything out beside the MD. You can attach a hose with will fit in the skimmer line, blow out the system until the water bubble for 1 minute and quickly plug the skimmer. The Cyclone with adapters, etc. will run around $350.
    Pool Parts Online with schematics from Pool Parts Store
    has all the adapters you will need. The Cyclone can be purchased anywhere. The online store has great customer service. Send them a message with dimensions, etc. and they will respond back to you. I find that going to HD or Lowes is a total waste of time when it comes to pool needs. Thanks!
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
