Thread: Holes in brick for pool cover
    Jul 2015
    Kings Point/NY
    8
    Is there a preferred way to drill the holes for an in ground pool cover on a brick patio? Specifically what I'm referring to is whether the holes for the tubes that will be used for the loops for the cover should be drilled in the middle of a brick or on the side edge or corners of a brick. I've heard different viewpoints. Thanks
    20 x 40 in ground gunite pool, brick patio & coping, salt water chlorination, 2 skimmers, four returns, auto fill & connection for auto vac
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Holes in brick for pool cover
    Loop-loc recommends installing between bricks or pavers when possible. Also, you should be using the anchor in pipe method for anchoring into that type of deck.
    See installation recommendations here: http://www.looploc.com/assets/dealer...ATIONGUIDE.pdf
    Isolated Spa - 345 Gallons
    Jul 2015
    Kings Point/NY
    8
    Thanks for the info
