Thread: expansion joint - caulk? grout? neither? makes no difference?
    Jul 2012
    Whidbey Island, WA
    397
    Old pool with expansion joints between coping slates and deck slates and various other places.
    Have obtained various opinions as to cover the joints with caulk, grout, nothing, or makes no difference.
    You all would recommend?
    Thank you
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    Re: expansion joint - caulk? grout? neither? makes no difference?
    Caulk is the way to go. Grout does not allow for expansion. Doing nothing allows water to get in, which can lead to erosion and ice damage.
    Support the site
    Jul 2012
    Whidbey Island, WA
    397
    Thank you
    Oct 2015
    Pentas/TX
    28
    When you clear out the old material from the joints. Take a look at the depth and even try to measure it. Some backer rod going in before your caulking will be very helpful if none is there already. Also, try to use some self leveling caulk. I use Adeka P201, but it is a bit overkill for decking expansion joints. Of course, I'm assuming you are redoing the joints entirely. You may have already been up to date on this just thought I'd mention it. Good Luck!
    40x20 Rectangular (3'to6' depth),Cantilevered Deck, Whisperflo 2HP FullRated, DE 60 SQft Filter, 2 Intellibrite 12V 5G Color Lights, Intellibrite Controller
    Jul 2012
    Whidbey Island, WA
    397
    Thank you. Will check out Adeka.
