Thread: Leak in winter cover
    May 2013
    Massachusetts
    148
    I believe I have a leak in my winter pool cover? I keep pumping water off of it, but the water never gets off the top part of the cover and water level has gone down dramatically?
    What do I do? Replace the cover? That's the only solution I can see because having this little water in the pool scares me.
    25,000 Gallons Inground, Gunite
    DE, Hayward Filter
    Loud pump
    Hayward navigator cleaner, leaf hose suction
    domct203's Avatar
    Jun 2015
    CT
    3,589
    Re: Leak in winter cover
    You should raise the water level in the pool if you are that concerned.
    The only options you really have is to either repair or replace the current cover, or deal with it until spring.
    If you decide to wait until spring, just don't pump as much water off the cover. The "hole" may let some dirt/debris in the pool that will need to be addressed when you open, but other than that it should not be an issue if the pool was closed properly.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,256
    ...If your pump is running and when done there is little water left, then you have a small tear in the cover. This means you finished and came back the next day to water back on the cover. You can leave the cover on, just allow the water to fill up. In the spring, pump water off the cover and back into the pool. As you are pumping water off, have a helper pull the cover on each side and support it so the cover is above the water line or you will be siphoning water from the pool (happened to me). Then you can either repair the cover or replace it.
    ... If your pump is running and the water is still on the cover, then you have a large tear in the cover. The cover should be replaced at this point. You could leave this on during the winter, just do not remove water unless it is extremely high in the pool. The water will also act as an insulator for the lower part.
    This year, what I have done is created a lot of slack in the deep end and by the steps so water can stay in this area. Covers have a tendency to rip in areas where they are being pulled (like a 90* degree corner), which you could place some foam padding, etc. I gave enough slack so hopefully there will be no problems.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    May 2013
    Massachusetts
    148
    Quote Originally Posted by Catanzaro View Post
    Yes, I think I will try to get the cover off the pool and just leave it. I read on the web that you can put the cover pump far away from the hole and that will stop you from siphoning water from the pool. I will adjust it that way.
    There is enough water in the pool (i have a gunite IG) that it won't "pop" out of the ground, as we are also on top of a hill and there is so way the water table is high enough, and there is still a considerable amount of water in the pool.
    DE, Hayward Filter
    Loud pump
