Thread: Solid CYA
    Apr 2015
    Katy, TX
    65
    Solid CYA
    I have read on this forum that we can purchase solid CYA at Walmart. Does anyone know the name of the product? I was not able to find this at the store. Thanks
    24K gallon, IG, plaster, Pentair Clean and Clear Plus Filter, Pentair Heater, Pentair Intelliflo pump, Built in March 2015, Taylor K-2006, Spa included
    Jun 2014
    15,298
    Re: Solid CYA
    Are you referring to the granule stabilizer at Wal-Mart? It has a purple lid (HTH brand) and is about $16 for a 4lb bottle.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: Solid CYA
    They often call it stabilizer.
    Apr 2015
    Katy, TX
    65
    Re: Solid CYA
    Ok I will look for that. Thanks. Is Walmart the only place that has the solid/granular CYA?
    Jun 2014
    15,298
    Re: Solid CYA
    You might also find it at one of the home improvement stores in their pool section if they still have any out this time of year. If not, you can order on-line or visit a local pool store.
    JoyfulNoise's Avatar
    May 2015
    13,263
    Solid CYA
    Ace Hardware typically has it in their pool section. You can also get it at Patio Pool stores (if you have those) or Leslie's. It's harder to find in the off season so you can always use Amazon if need be.
    Amazon has 6lbs BioGuard Stabilizer 100 (pure CYA) for $30 + $8 shipping. That's what I used this past year.
    Matt
