Thread: Mesh Safety Cover - use "pillows" underneath it or not?
    Jun 2014
    Grapevine, TX
    12
    Our "freeform' pool has a custom mesh safety cover. It's the type where the mesh fabric is sewn to a 3' x 3' grid of heavy-duty "straps" that extend horizontally and vertically across the pool. Each of those straps is tied down to an anchor at either end. Those anchors are positioned about 3' apart around the perimeter of the pool. Even when those straps are tightened down to their anchors, however, the cover still droops a bit into the water near the middle of the pool (our small dog enjoys running across the cover and splashing in the water.)
    During the winter, the cover collects leaves and debris, and most of that ends up in that "wet" portion of the cover.
    I'm about to put the cover on again, but I'm wondering if it might be a good idea to first lay some of our inflatable floats in the center so that, when I do install the cover again, the inflatable floats would lift and keep that center portion out of the water. It seem like that would help cause the leaves and debris to locate closer to the edges where they would be easier to periodically remove.
    Any thoughts about this, good or bad?
    Re: Mesh Safety Cover - use "pillows" underneath it or not?
    You should be able to tighten the straps a bit so it doesn't sag.
    wjr75's Avatar
    Jun 2013
    IL
    836
    Not sure if you have a liner or not? We have plaster and they drain 2 ft of the water before putting on the cover. By the spring water is back up to the skimmer. If you don't drain any water it will be on top of your cover for sure.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    wjr75's Avatar
    Jun 2013
    IL
    836
    I should also note that you should have springs attached to the cover straps which connects to the anchors in the concrete.
