Thread: pentair easytouch 8 remote stopped working buy new or screenlogic2?
    May 2013
    austin/texas
    140
    I tried using my easy touch 8 pentair remote (520690) but it won't power up. Changed the batteries but no dice. Checked all contacts in battery compartment there is no corrosion looks like new. Remote has never been submerged in water either. I even changed batteries twice but it's still not powering up. Anyone else had their remote completely die like that?
    Looking online found it around $450, which seems to be same cost with the screenlogic2 system (pentair 520500)which seems to be a better option. Thoughts/experiences with screenlogic2 system, will my wireless transceiver from the easytouch8 remote work with the screenlogic2 ?
    34x15, 17K Fiberglass In-Ground Leisure Morroccan SWG, 1 1/2HP 2 speed SuperfFlo pump, Pentair Intellichlor SWG, Pentair Clean & Clear 320 cartridge filter, Pentair EasyTouch 8 panel, 4 returns, 1 skimmer, Installed August 2013, Fiberstar 3-color LEDs, AquaBot AWD robot cleaner, Pentair Easy Touch 8 Wireless remote.
    Dec 2014
    Riverside California
    482
    Re: pentair easytouch 8 remote stopped working buy new or screenlogic2?
    I think you are much better off to go with the screen logic. I do not think your wireless transceiver is compatible with screen logic. You can get a screen logic wireless bundle for around $370. I got mine at Sunplay.com, they seemed to have the best prices and their delivery was quick.
    http://www.sunplay.com/pentair-scree...ireless-522104
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Ours stopped communicating with the Panel after 10 months and was replaced under warranty. If you're out of warranty, I would do the Screen Logic.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    May 2013
    austin/texas
    140
    mine won't even power up which seems weird since I've changed the batteries.
