Thread: Outdoor Spa not sucking air
    Oct 2015
    VIC
    1
    Question Outdoor Spa not sucking air
    Hi all,
    Hoping someone can help me, I purchased a secondhand spa that's been barely used and looks like it's in good nick.
    Issue is it's not sucking air through the airline, when I turn on the spa pump, water starts pushing itself through then airline and starts spitting out a little through the air nozzle.
    It a 4-6 man spa running a 2.5 HP pump with 8 jets.
    It doesn't have an air blower or anything, just a simple nozzle on the top of the spa to control the amount of air-flow.
    It's not clogged, I've blown into the air-lines and there's no restriction.
    When I first turned on the spa, the air worked for 2 seconds then water started filling into the airlines.
    I've attached a photo of the air-lines and nozzle used.
    Really hoping someone can work this one out... I'm stumped
    Thanks
    Jun 2015
    Wildomar, California
    423
    Re: Outdoor Spa not sucking air
    If water is backing up thru your air line, check for jet blockage, or something plumbed wrong.
